Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->REMOVAL OF THE BOTTOM OUTER WINDOW TRIM<!-- google_ad_section_end -->
Published by tomtom23a
15-06-2013
Difficulty Level: 2
User Rated:Unrated
What I did was took the mirror off, then found the thinnest screwdriver possible, removed the inner trim, look near the mirror from the inside the car you can see the underside of the trim piece, get your get thin screwdriver and place it in the lip where it grips, prise it away and use another screwdriver to push up and once you have the first couple of inchs off the rest will come off by hand.........................................
Old 09-08-2014   #1
Young Efficient has donated!
Re: REMOVAL OF THE BOTTOM OUTER WINDOW TRIM
I tend to find winding my window up on a hot day does the same thing.
http://s.fiatcdn.com/signaturepics/sigpic148429_1.gif
899cc 1.4l White Night and Day Cinq.
1.1l Red Seicento Sporting MPI
Young Efficient is offline Reply With Quote Quote
Old 08-01-2015   #2
The seal on my daughters Seicento 52 plate comes off when I roll the windows up. Do I need a new one?
It stays fastened in at the front of the door but the rest comes out everytime!
markaz is offline Reply With Quote Quote
Old 13-04-2021   #3
Gibraltar
Quote Originally Posted by markaz View Post
Did you find a solution? Mine does too.
Tychy is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Replacing the outer window seal in 10 minutes! solpap Cinquecento / Seicento 2 4 Weeks Ago 20:11
(T) Outer CV Joint Removal On Punto Mk2 Cinqster355 Punto (Mk2/2b) 3 01-04-2013 12:48
(T) Outer CV joint removal widemouthfrog Multipla 1 13-08-2012 15:09
(G) Outer drivers door window rubber seal and plastic scottishseicento Cinquecento / Seicento 1 05-10-2011 22:02
(T) Bottom pulley removal AIJ29 Cinquecento / Seicento 3 20-05-2006 18:29
