Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Blocked Rear Washer<!-- google_ad_section_end -->
Blocked Rear Washer
Published by micsy
07-03-2009
Unrated
User Rated:Unrated
Blocked Rear Washer
Ok I tried using a hose pipe but it wouldn't work. Instead I used an air pump. First thing disconnect the rubber tube at the top right of the open tailgate.
Now just put the air gun to the washer nozzle and press go. I didn't try blowing air through the rubber tube as whatever was blocking the nozzle was obviously too big to go out that way.
Now just wipe of the lovely gunk that was blocking your washer.
Yes I know this is perhaps an obvious solution but it might help people with the same problem to have confirmation that this works.
Thanks HannahM thanked for this post
Old 09-04-2011   #1
Re: Blocked Rear Washer
Part of my rear washer is missing which means i get a jet of water squirting about 2 feet behind the car. Do you know how to replace the washer as i have tried to pull it out to no avail and I cant get to the other side. Is it glued in or is heir a hidden bolt?
amariner is offline Reply With Quote Quote
Old 02-09-2019   #2
Italy
On my Seicento water cames out from the engine bay when i hit the rear washer (
ctln91 is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
Hi, there is a one way valve which fails and can lead to a leak. Its hard to spot a it's in the wiring harness at the font with the big multi plug and other wires all held together with clips etc. Or it could be the pump (separate one for back) or pipe leak under the water tank which is in under the screen wash filler and visible if you can get under the car safely.
Bob cinquecento sporting is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Rear Washer Tris Harris Grande Punto 2 08-12-2008 00:16
(T) Rear Washer wibblemonkey Punto (Mk2/2b) 2 18-10-2008 14:52
(G) Rear Washer blocked Capt T Ulysse 5 03-03-2006 19:18
(T) rear washer luke64 Cinquecento / Seicento 5 04-12-2005 14:56
(G) Rear washer Warful Cinquecento / Seicento 11 06-04-2005 16:26
