Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Oil and Filter Change<!-- google_ad_section_end -->
Published by FIREsporting
24-04-2007
Unrated
User Rated:Unrated
1st warm the engine by driving the car for about a mile to get it up to operating temperatuer. then switch the ignition of then apply the handbrake now jack up the front off the car then support it on axle stands, remove the oil filler cap from the top of the engine to allow the oil to drain more quickly. loosen the drain plug about half a turn. put the container in position and unscrew the plug by hand be careful not to drop it in the container. now u can remove the filter & screw the new filter on by hand. refittng the drain plug then take out the dipstick now fill the engine using the correct oil wait a minute for the oil to fall the sump then add more put the dipstick in & look & see if u need more on the level in between lower the upper marks on the dipstick. put the filler cap on and now start the engine and look for the oil light to go out. now switch it off and rechck the level on the dipstick add more if u need to.
Old 27-04-2007   #1
4RL has donated!
Ninja Turtles 2 Champion
Re: Oil and Filter Change
you may want to smear a small bit of oil around the filter seal as well.
4RL is offline Reply With Quote Quote
Old 27-04-2007   #2
Sei Sporting abarth
FIREsporting has donated!
Quote Originally Posted by 4RL View Post
yer i do some times it's wot mood im in at work lol
FIREsporting is offline Reply With Quote Quote
Old 11-09-2008   #3
The above guide is how it is done by a mechanic at a garage, most of it is good advice.
BUT, if you are doing it yourself do it properly.
1..... It takes more than a mile run to get the engine up to operating temprature, allow about 5 miles.
2..... Do not remove the filler cap completly, loosen it enough so air can get in but the hole is still covered so dirt will not get in.
3..... Leave the oil to drain from the sump and oil filter housing for as long as possible, this allows more of the old oil to drain out, do the other servicing on your car whilst it is draining.
4..... Always smear the seal of the new filter with clean engine oil before fitting! Not how the mood takes you.
Always check there are no oil leaks from the filter and sump plug with the engine running after everything is completed !
F500MS is offline Reply With Quote Quote
Old 20-02-2009   #4
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
needs updating! oil filter codes and quantity of oil would be a nice extra ( i dunno how much oil i menta put in and cant be arsed to look for manual grr lol
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 24-02-2009   #5
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Quote Originally Posted by craigb244 View Post
if only there was some sort of FAQ
Old 24-02-2009   #6
Trader Rating: 1
Quote Originally Posted by custard View Post
oooh ok but surely the info NEEDS to be in the guids to
Old 24-02-2009   #7
custard's Avatar
Trader Rating: 1
well make it
who exactly do you think makes the guides? people are not paid to make them
perhaps you would like to lead by example?
Old 24-02-2009   #8
Trader Rating: 1
make a whole new oil/filter guide just to add a few bits? imho the guides/faqs would be a LOT better if they where run wikipedia style
Old 18-04-2009   #9
Where is the MAP sensor on amarea JTD
briarsue is offline Reply With Quote Quote
Old 28-07-2009   #10
the author should seriously consider putting some punctuation and spacing in his guide. it reads as garbage at the moment. not very helpful content anyhow.
soundofsilence is offline Reply With Quote Quote
Old 28-07-2009   #11
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Quote Originally Posted by soundofsilence View Post
Ouch... the author will have done this for free out of the goodness of their own heart to be fair.....
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 14-09-2009   #12
Ghost Hunter Champion
Quote Originally Posted by Ffoxy View Post
Not to take sides or anything but you are true people on here should accept that the guide is good enough for people to understand.
PUNTO SX 97 1.2
MODS:Clear Side Repeaters/Smoothed Sides/Janspeed Exhaust
NEEDS:Lowering/Bodykit/Debadged
Dont Forget to Thank Me
MyPunto
unimatrix1 is offline Reply With Quote Quote
Old 14-09-2009   #13
custard's Avatar
Trader Rating: 1
i think somebody needs to take their username a touch more literally
perhaps even more so when you need to ask how to fill up the oil
Old 02-10-2009   #14
Its a good guide but update it with the following.
Size of driver needed to undo sump plug.
What viscocity of oil (lots of old twaddle spoken about synthetics).
Amount of oil needed in the sump.
(I think its 3.2 litres in oil filter but I stand to be corrected).
Like I said,its a good guide and everyone should know how to change their oil.
Also,remember old oil is to be recycled at the council depot and not put down a drain.
Wear rubber gloves too,old oil can cause cancer.
RALPH
ralphtown is offline Reply With Quote Quote
Comment
Search this Guide:
Instructions for oil change Koa Leisure Lounge 4 12-08-2009 12:44
Oil Change bhinderharminder Leisure Lounge 8 26-03-2009 15:51
Oil and Filter Change topcat5 Lets Talk FIAT 4 12-02-2007 12:28
oil - question for GC Hellcat Lets Talk FIAT 47 17-01-2006 13:54
(T) Oil & Filter change today - bit of mayo :( pritch Punto (Mk2/2b) 1 09-01-2006 01:43
