first thing you need to remember is a standard 4 cylinder rev counter(tachometer) wont function on the centos if you connect by the standard method.
that is taking a feed from the coil signal wire.
the reason for this is the cento uses 2 coils.so using a feed from 1 coil would give a reading of only 50% of the actual RPM
