- Reference : R/2000/051
- Manufacturer Ref :
- Make: FIAT
- Model : Seicento (RHD)
- Launch Date : 28/04/2000
- Numbers Involved : 3346
- Build Start Date : 01/09/1999
- Build End Date : 31/10/1999
- Concern : DRIVERS AIR BAG MAY BE INSECURE.
- Description : The mounting bracket within the steering wheel for the driver's air bag may be cracked. This could make the air bag insecure.
- Remedial Action : Recall affected vehicles and replace bracket with modified type.
- Vehicle Id : 00337236 to 364472
- Reference : R/2000/071
- Manufacturer Ref : 4283
- Make: FIAT
- Launch Date : 19/06/2000
- Numbers Involved : 292
- Build Start Date : 01/07/1999
- Build End Date : 31/08/1999
- Concern : BRAKE PEDAL MAY FRACTURE
- Description : There is a possibility that the brake pedal is of incorrect specification and could eventually fracture.
- Remedial Action : Recall affected vehicles and replace brake pedal with quality assured type.
- Vehicle Id : 294228 to 302284
- Reference : R/2000/117
- Manufacturer Ref : 4089
- Make: FIAT
- Model : Seicento
- Launch Date : 07/12/2000
- Numbers Involved : 1084
- Build Start Date : 01/01/1998
- Build End Date : 31/12/1999
- Concern : POSSIBLE CHAFING OF BRAKE PIPES.
- Description : Possible chafing of front rigid brake pipes at near side front against the plastic wheel arch liner or against the gearbox mounting. Also at the off side front against the engine timing belt cover.
- Remedial Action : Reposition any chafing brake pipe to comply with the manufacturer's prescribed clearance between adjacent parts. Renew any brake pipe that has been chafed beyond a serviceable condition.
- Vehicle Id : ZFA187000000001 to ZFA18700000192967
- Reference : R/2004/049
- Manufacturer Ref : 4678
- Make: FIAT
- Model : Seicento
- Launch Date : 30/04/2004
- Numbers Involved : 16175
- Build Start Date : 01/03/1998
- Build End Date : 01/09/1999
- Concern : POSSIBILITY OF LEAKAGE FROM FUEL TANK DUE TO CORROSION
- Description : Possibility of fuel leakage from the fuel tank due to corrosion
- Remedial Action : Likely to be affected vehicles will be recalled, during which time the fuel tank will be inspected for corrosion. Should corrosion be found, the fuel tank will be replaced.
- Vehicle Id : ZFA18600000000010 to ZFA18600000368384
