Old 19-08-2020   #1
Squeaking nose from 2007 Panda
Hi
I bought my 2007 1.2 Panda earlier this year and until recently it has being running fine.
It has started to make a high-pitched squeaking noise while cruising, the noise appears to marry up to car's speed and strangely the noise stops when turning either way.
The noise doesn't appear until the afternoon though; my morning commute is squeak-free.
A quick visit to the garage wasn't able to diagnose it, although they suggested it could be the gearbox, which would cost more to even fix than the car is worth...
Just wondering if anyone else has had a similar issue....
thelartman is offline Reply With Quote Quote
Old 19-08-2020   #2
varesecrazy has donated!
Re: Squeaking nose from 2007 Panda
Hi
it is 90% sticky brake on front.. if you dab the brake pedal it will stop
Ours did this last year
New gearbox..??
Did it look like they had no other cars to work on..??
Charlie
Likes Pugglt Auld Jock liked this post
varesecrazy is online now Reply With Quote Quote
Old 19-08-2020   #3
Trader Rating: 1
portland_bill has donated!
Absolutely a sticking brake.
Garage that suggested gearbox is one to avoid.
Panda pad carriers gently corrode, causing the pads to stick and rub gently on the discs. It all flexes a little on turns, which is why the noise changes.
Annually, hook the pads out, scrub the carriers with a wire brush, or a dremel if not wishing to work too hard, but don't take off too much material. Reassemble with a little smear of copper grease or ceratec.
Make an entry into next year's diary to do it all again.
This is not unique to Panda. It has affected disc braked cars since discs were first fitted. Some are more susceptible than others. Any garage that does not look at or suggest this first needs avoiding.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
(T) 2012 Panda Lounge 1.2L Squeaking Cameron1590 Panda (2012+) 2 04-12-2017 14:31
(T) Panda light squeaking noise from front wheels? AlexisAngeles Panda 7 29-07-2013 22:19
(T) fiat panda front wheel squeaking noise? AlexisAngeles Panda 1 12-04-2013 20:35
(T) one week old panda squeaking! CookieLad Panda 6 29-12-2009 22:42
