FIAT Auto Specialist Team
Old 17-03-2019   #1
Recirculation?
63 plate 500C. Correct me if Iím wrong, recirculation should only be used if the air outside is polluted, because it causes fog on the inside windscreen. My recirculation button keeps turning on by itself! Any idea why? Iíve only had it a few weeks so still getting used to everything.
Chersbxtch is offline Reply With Quote Quote
Old 17-03-2019   #2
chris3234 has donated!
Re: Recirculation?
It turns itself on?
On I've never known any car that turns itself off
I assume you have the climate control as it's a manual twist switch otherwise
chris3234 is offline Reply With Quote Quote
Old 18-03-2019   #3
Trader Rating: 1
portland_bill has donated!
Re: Recirculation?
If it has auto climate control, the auto setting will often use the recirculate for short periods, to speed up the warming or cooling process. It should go off after a short time, generally no longer than 10-15 minutes.
Let it do its stuff.
In the centre of the dash, below the heater controls is a small vent. Run the fluffy brush of your vacuum cleaner across is gently. This is the temp sensor for the auto control, and if full of fluff can cause temp sensing to be erratic, or just tardy.
When I got the Panda, the auto climate was a bit slow to react to temps changing, waiting unitl we got quite warm before it cooled us, and later, waiting unitl we were shivering before adding heat. Two minutes with the vac, and all has been fine for the last nine years.
Likes Ralf S. liked this post
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
(T) Recirculation valve come off?? Luke torr Grande Punto 7 10-09-2015 16:32
(T) Recirculation button FatherJack Grande Punto 13 06-12-2013 22:41
Air recirculation Fabio Souto FIAT Boo Archives 3 21-08-2010 01:49
Air Recirculation TDF Lets Talk FIAT 5 25-09-2005 08:20
recirculation mark FIAT Boo Archives 3 21-01-2003 15:18
