Sei: Paraflu or any antifreeze?
so 50:50
antifreeze & distilled water you mean. This will be the same as Paraflu eqvilent (spelling)?
thanks
cool, that's answered my question. How do you drain the old coolant out the bottle? in order to put the new stuff in?
Thanks again
custard boy said:
no need for distilled water in the cooling system and dilute as per the pack instructions. you will have no problems
It's OK for you back home Custard to say this as we have nice soft water in Scoltand that is easily good enough for the coolant system, but down here in South England, especially when I lived in Bourenmouth, the water is so hard that I wouldn't use it as I've seen some real clogged up coolant systems in the few years i've lived down here with limescale!
I use a big bottle of cheap drinking water from ASDA 5L for about £2.50 job done, all the cars I have done this to have run cooler and heated up quicker after a good heavy duty coolant systems flush and change with new anti-freeze.
Aaron.
Aaron.
ah well its our secret plan to gunk up all off the southerners insides :D
If you look under the bumper you will see the radiator on the drivers side. The hose you want to pull of is the one coming off the bottom of the radiator - it might be difficult to shift, so try twisting it while pulling very hard! ;)
OK
atm I have 'green' antifreeze. Would it be possible to top this up with the blue stuff, diluted of course?
Thank you
thanks for that
anyone else if deffo not then I'll have to try to drain the rest out.
Surely you can't keep topping up with water all the time. It's very diluted atm.
come on guys. I'm really dissapointed that no one's answered. Someone must know. Thanks again...
Michael
Best not to mix any anti freeze unless you know exactly what it is, some better garages put a sticker on the rad end cap with a date and type used, but most don't, so drian system and flush with a propriety cleaner and refill then you knoe everything is correct.
And stick something on end cap with water proof ink to indecate you have done it.
Aaron.
