hey i have a 81 fiat spider FI timing belt was loose tension pulley did not seem to move spring is intact pulley rotates how does one adjust tension pulley ? have new belt but still loose any help will be thankfull
ask in the spider section.. but my suspicion is the cam-belt idler bearing is mounted on a thick "washer" with an off-set 8mm hole,
this is then placed onto a stub/ bolt, and you use a pair of pliers , etc to twist the mount around and tension the belt, then tighten the 13mm AF nut / head to final tension,
this MAY give you an idea ( different engine - similar tensioner)
