Thread Tools
Old 21-11-2012   #1
1.4 16v Nissan Note Visia
Magic Johnson's Avatar
Magic Johnson has donated!
Mould
Got some green mould on the seals of the windows in the doors.
How can I get rid of this and prevent it? I know any sort of mould remover would decimate the rubber seals, so any ideas? Just wipe it off with kitchen roll or something?
Likes SJB1985 liked this post
Magic Johnson is offline Reply With Quote Quote
Old 21-11-2012   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Mould
clean your car more often you scruff :-P
A decent all purpose cleaner eg daisy from tesco or flash and a paint brush will be your best safest bet then rinse with pressure washer to start with and a regular wash
if it keeps coming back
a body shop solvent panel wipe should kill any spores as too will a decent mix of tfr traffic film remover
if it comes back a very weak bleach solution and repeat
Thanks SJB1985 thanked for this post
Old 21-11-2012   #3
If it makes you feel any better its not mould, its algae.
jameshobiecat is offline Reply With Quote Quote
Old 21-11-2012   #4
Re: Mould
Quote Originally Posted by jameshobiecat View Post
That's it.
I do clean my car a lot! I thought a bleach solution would eat away at the rubber, am I wrong?
Old 21-11-2012   #5
Grande Punto Fanatic
SJB1985's Avatar
SJB1985 has donated!
Re: Mould
Quote Originally Posted by Andy Monty View Post
Thanks Andy mate I was meaning to ask this question myself so thanks for the answer!
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.”
Instagram: 1985SJB
SJB1985 is offline Reply With Quote Quote
Old 21-11-2012   #6
Moderator
Andy Monty's Avatar
Quote Originally Posted by Magic Johnson View Post
That's it.
almost everything attacks rubber over time even sun light but a weak solution should have no
detrimental effect
a propriety rubber dressing after is always a good idea
see how the milder chemicals first though
Old 21-11-2012   #7
Re: Mould
Use Autosmart G101 - diluted about 12:1.
It is an excellent all round cleaner and superb value for money - It can be used on all fabrics and plastics when diluted. Working on the premise that AG Interior Shampoo is about £7 - this stuff works out about 100 times cheaper.
If you're interested;
http://www.clbcarcare.co.uk/autosmart-g101-500
Rosso145 is offline Reply With Quote Quote
Old 21-11-2012   #8
Moderator
Andy Monty's Avatar
Re: Mould
Autosmart are getting very unhappy with people decanting these sort of products and selling them to the general public without the required safety data....
I picked 5l up from a AS rep for £15 so that's not very cheap either If not used correctly it can cause staining to paint work and plastics and in its concentrated formula is corrosive......
Yes its good but not really a home user product unless you are very careful
To be honest i much prefer Bilt hamber Surfex over G101
12:1 is rather strong for general cleaning
1:30 it cleans most things
used for degreasing they recommend 1:8 (but since most engine tops are bare aluminium its probably not the best thing to use in the engine bay
Massive gash
Just a little touch up
Old 23-11-2012   #9
Re: Mould
There's not much that Autosmart can do, to be honest.
30:1 is too weak for me - I use is at about 12:1 to 15:1 problem free but it is ALWAYS safe to check a small inconspicuous are first.
"Autosmart G101 is a highly concentrated multi-purpose cleaner, and should thus always be diluted to an appropriate strength before use. For general cleaning duties it should be diluted 30:1 (waterroduct), while for more intensive degreasing duties it should be diluted 8:1 (waterroduct). Autosmart G101 may also be used for wheel cleaning and synthetic sealant removal duties; in such cases it should be diluted 5:1 (waterroduct) and spot tested before use. In all cases, an appropriately diluted solution should be sprayed directly onto the surface to be cleaned and then agitated thoroughly with suitable detailing brushes before being fully rinsed off. Ensure that you never allow Autosmart G101 to dry out fully before it is rinsed off, otherwise permanent staining may occur."
Thread Tools
Mould deverill Car Care 9 08-05-2011 00:16
cinquecento mould :P craigk Car Care 4 02-03-2011 14:39
I just nearly drank mould... Chrisst10 Leisure Lounge 18 21-02-2008 11:14
mould custard Car Care 16 11-03-2007 21:22
Best way to get rid of mould? helpimonfire Leisure Lounge 15 17-04-2006 21:32
