![]() | #1 | ||
![]() | Results Well for those who read my thread about Diamondbrite (couldn't find the old thread, unless I'm blind) but here's some results. (please, it's my first time properly cleaning my car haha)
![]() | #2 | ||
![]() | Re: Results Cars looking good, black cars always do after a good wash an polish. Is this the thread you ment? https://www.fiatforum.com/car-care/2...mondbrite.html just gona have a read of it now. Rich
![]() | #3 |
Posts: 1,553 Thanks: 60 Trader Rating: 0 ![]() | Re: Results i love clean black cars easy to polish up but for me get dirty far to quick ![]()
__________________ "59" MX-5 MK3.5 owner. |
![]() | #4 | ||
![]() | Re: Results Bad news; it's gone back to the way it was... I'm pretty pissed off if I'm honest because I don't know why it's done that ![]() I spent 4 hours 2 weeks ago 'polishing' or 'correcting' it.. and I don't know why it's gone back to the way it was.. all the scratches and swirls are back. Did I do something wrong? ![]() EDIT: Examples -
![]() | #5 |
Posts: 1,553 Thanks: 60 Trader Rating: 0 ![]() | Re: Results what exactly did you use on it it makes it easier to identify? if youve used SRP then its full of some cutting properties but also fillers and if the fillers have worn off then thats the reason they may be back....
![]() | #6 | ||
Posts: 150 Thanks: 5 Trader Rating: 0 ![]() | Re: Results As Ninja59 said could be down to fillers wearing off. Also the marks around the door handles look like buffer trails not scratches. Maybe caused by not holding the machine polisher upright and placing more pressure on one sie of the pad.
![]() | #7 | ||
![]() | Re: Results I used Auto-balm. And I don't have a machine polisher ![]() Would I need a sealent after using Auto-balm?
![]() | #8 |
![]() | Re: Results it doesn't bead like a wax but offers good protection and can be "topped up" using an applicator to dry the car with a very small amount of balm on then buff over with a dry Microfibre ![]() as for the swirls it looks more like hazing at a guess did you use a lot of auto balm it could be residue try a plant spray bottle with water in mist the panel then buff with a clean microfibre see if it comes off
__________________ What Goes Up Must Come Down..... Last edited by Andy Monty; 22-02-2010 at 18:16. |
![]() | #9 |
![]() | Re: Results have you actually 'corrected' it then if you havent used a machine polisher? 4 hours by hand isnt going to correct much... not ripping you apart by the way, just correcting by hand would take about a year!
__________________ ![]() |
![]() | #10 |
Posts: 1,553 Thanks: 60 Trader Rating: 0 ![]() | Re: Results they look a little like residue pics where your polishing asnt wiped away all the polish on a second look
![]() | #11 |
![]() | Re: Results dont use the supplied scrim get some decent microfibres they should remove it with a mist of water if you still have a problem damp aplicator and a touch of balm work it in really well then buff it straight off (if you can see more than an oily film you have used way too much) Did you balm the entire car then begin to buff it off? you almost want to apply it so you cant see it..... give you an example i did my mums KA by hand using only what was stuck to the lid you should be able to get 20- 30 GP sized cars out of one pot.... 1/4 of the roof is sometimes too much to get it off before it cures small areas at a time ![]() why am i still sat on the computer when i should be in bed ![]()
__________________ What Goes Up Must Come Down..... Last edited by Andy Monty; 22-02-2010 at 23:14. |
![]() | #12 | ||
![]() | ![]() No it doesn't bead like a wax but offers good protection and can be "topped up" using an applicator to dry the car with a very small amount of balm on then buff over with a dry Microfibre ![]() as for the swirls it looks more like hazing at a guess did you use a lot of auto balm it could be residue try a plant spray bottle with water in mist the panel then buff with a clean microfibre see if it comes off well thats what i think it is too Ninja ABalm can be a pig to remove if you put it on too thickly dont use the supplied scrim get some decent microfibres they should remove it with a mist of water if you still have a problem damp aplicator and a touch of balm work it in really well then buff it straight off (if you can see more than an oily film you have used way too much) Did you balm the entire car then begin to buff it off? you almost want to apply it so you cant see it..... give you an example i did my mums KA by hand using only what was stuck to the lid you should be able to get 20- 30 GP sized cars out of one pot.... 1/4 of the roof is sometimes too much to get it off before it cures small areas at a time ![]() why am i still sat on the computer when i should be in bed ![]() P.s. if I don't reply that's because I'm off to Tenerife in 5 hours ![]()
![]() | #13 |
![]() | Re: Results Yeah well from what I gather it is more residue than anything, but when I dry off with my microfibre cloth after washing it streaks the car. So you can't really get correction by hand? If so what MP could I get ( I've seen this - http://www.lidl.co.uk/cps/rde/xchg/l...index_8400.htm ) and would I have to use some other polish to correct it, then wax the car? P.s. if I don't reply that's because I'm off to Tenerife in 5 hours ![]() dont get that something like a kestral DAS6 is what you want... If the car is streaking after washing i guess your using a cheaper wash and wax type product try a decent quality shampoo (mixed to the correct dilution) and rinse VERY well then dry (i take it your drying cloth is clean too) |
![]() | #14 |
Posts: 1,553 Thanks: 60 Trader Rating: 0 ![]() | Re: Results CG Maxi Suds, ONR, DG 901, Zaino Z7
![]() | #15 | ||
![]() | Re: Results Okay I've decided I'm no good at this and I give up lol, I tried some more today on the bonnet and I only put a tiny bit on at a time, took me forever, and it won't buff off it just is streaky and metallic looking...
![]() | pietch | Grande Punto | 5 | 12-03-2008 03:14 |
GCSE results! | Gav F | Leisure Lounge | 19 | 24-08-2007 12:35 |
Exam Results | smokeyjoe03 | Leisure Lounge | 20 | 17-08-2007 18:51 |
![]() | MintySport | Cinquecento / Seicento | 15 | 12-09-2005 22:54 |
