F**k, foam can!
F**k, foam can!
Hamilton, Glasgow
I managed to cover the inside of my car with the foam out of the compressor for around a second, forgot to take the air hose out the foam can!!! :bang::bang:
anyway once the foam has been used does it have to be replaced or can i use it again, it was only on for a second or two? there was a "pop" noise before the foam squirted so im unsure if there is a seal?
interior is a right mess :mad:!!
ps, ive put a tread in car care for any tips to remove this foam from the seats, any help would be great.
:bang::bang::bang::bang::bang:
il get a price for a new foam can at the dealers tomorrow.
Tardis seems to get the "goo" off ok, tried heavy duty APC with different dilution ratios and nothing worked.
put the tardis on and it immediatley melted the goo, used a brush to scrub it off and then rinsed with plenty of clean water to remove and excess tardis from the fabric.
so if anyone does what i did, tardis seems to be the answer haha! (y)
You either need to melt it out or dry it out, hairdryer and lots of paper towels to get the stuck on stuff off.
a tar and glue removed should shift the stuck on stuff, but it might take some scrubbing to get the staining out. Stick to a small test section and hope for the best.
