Thread Tools
Old 20-02-2009   #1
899cc Of Raw Power
micsy's Avatar
micsy has donated!
Quick Question-Basic Wash
Ok I have used the search function and found a lot of useful stuff. But before I go spending money I just want to make sure I know what I am doing.
1.Wash (called pre wash on some threads I've read)
-Do all dirtier areas first or with different stuff.
-First Rinse
-Then Shampoo-two buckets and wash mitt, from what I have read you can't go wrong when buying shampoo as long as you use common sense.
-Then Dry-Good quality cloth with a little detailer.
2.Clay
-Bilt Hamber soft clay with a water lube.
3.Re Wash.
-As in step one but no detailer when drying.
4. ???
-Bilt Hamber Auto Balm seems to be the next step -paint clenser filler and sealant all in one.
I realise you probably answer these questions every day, but I have grown up in a house where car wash means half an hour - hose it down, one bucket with a bit of shampoo and yellow sponge hose it down again, and that's it.
Also how often does this need doing, from what I have read step 1 is weekly, then doing all of the above bi-monthly (sp?).
Last bit. After having a look round the shed I found an AA Car buffer and T-Cut but I can't really make sense of what these are for as whenever they are mentioned the above washing procedure does not seem to be involved. Obviously the buffer is for buffering but when using what product, I can't see it fitting into any of what I have described. T-Cut seems to be for restoring paint work but in what scenario i.e. after it has been washed, waxed and sealed, or before, whole car or affected areas?
Thanks for your help.
p.s. sorry I know i said quick question but I got carried away
p.p.s. If it's relevant I am talking about my black cinq. Doesn't seem to have any excessively worn paint anywhere, it's dirty a.t.m. but I'm to blame for that, I have persuaded myself it's not worth doing as the rain will just make it dirty again.
'97 Cinquecento AKA The Beast Mk.2
Quote Originally Posted by little_yellow_beast View Post
p.s you need to change the name of your car because mine is called the beast lol
micsy is offline Reply With Quote Quote
Old 20-02-2009   #2
899cc Of Raw Power
micsy's Avatar
micsy has donated!
Re: Quick Question-Basic Wash
Can't edit for some reason. When I said 'do all dirtier areas first or with different stuff' what I meant was dirtier areas last, clean areas first.
Old 20-02-2009   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
there is no need to use quick detailer if your going to clay the car but on a weekly wash it can help preserve the shine..
pre wash is exactly that it removes the thickest of the grime
other than that your sorted in your proposed method
I wouldn't bother using the t-cut unless your planning on polishing out scratches and if your car is clear coated it'll make a mess (unless you finish off with a finer polish)
Bilt Hamber have a discount pack
including shampoo, clay and autobalm (pay the 1 extra and get the soft clay its much easyier to work with in the cold)
oh and leave the AA buffer in the shed you'd be better by hand (Unless you go out and invest in a proper machine polisher)
i start be cleaning the roof then glass then bonnet then sides down to about 1/2 way then boot lid then finnish off the lowers and bumpers (where most of the dirt tends to be)
Thanks micsy thanked for this post
Massive gash
Just a little touch up
Old 20-02-2009   #4
899cc Of Raw Power
micsy's Avatar
micsy has donated!
Thanks alot, Car is really desperate for a clean. It's got to the stage where people are writing messages on the back... you know the type: Clean me or I wish my wife was this dirty etc.
Old 22-02-2009   #5
andy, link to the pack?/
mills705 is offline Reply With Quote Quote
Old 22-02-2009   #6
899cc Of Raw Power
micsy's Avatar
micsy has donated!
https://www.fiatforum.com/car-care/1...ce-needed.html
Found it on this thread. Although as he says to get the soft clay you need to phone order.
Thanks Andy Monty thanked for this post
Old 22-02-2009   #7
Moderator
Andy Monty's Avatar
Quote Originally Posted by mills705 View Post
http://www.bilthamber.com/bilthamber-special-offers.php
Thanks mills705 thanked for this post
Massive gash
Old 25-02-2009   #8
899cc Of Raw Power
micsy's Avatar
micsy has donated!
Just about to order that pack. What else will I need?
2 Buckets, Drying Cloth, Glass Cleaner.
Also am I right in thinking the chamois is an alternative to the wool mitt?
micsy
Old 25-02-2009   #9
899cc Of Raw Power
micsy's Avatar
micsy has donated!
Doh! Ask a stupid question . Just had a quick search and as far as I can tell the chamois is the drying cloth.
Old 25-02-2009   #10
Angel:Mum of the *****
Ninja59's Avatar
Ninja59 has donated!
Correct drying cloth is a replacement for the chamois as it would cause scratches to the paint surface...
"59" MX-5 MK3.5 owner.
Ninja59 is offline Reply With Quote Quote
Thread Tools
(G) Anyone looking for a quick way to wash their baby? roadster1_98 500 7 25-05-2008 22:35
Mums Corsa Quick wash with a foam gun. Ant1974 Car Care 10 08-03-2007 21:09
Quick one - basic forum question! Dr_Pepper Leisure Lounge 6 18-04-2005 21:39
Basic Question... Chassis number... jdillon Lets Talk FIAT 2 07-04-2004 22:43
