Comment
Guide Tools
<!-- google_ad_section_start -->Bravo Air Filter Box Removal-Refitting<!-- google_ad_section_end -->
1.4 T-Jet Engine
Published by PeterMmX
28-03-2009
Unrated
User Rated:Unrated
Removing
Position the vehicle on a lift.
- Remove right front wheel
- Remove right front wheel arch liner
Photo 1 - Loosen the band and disconnect the turbocharger air supply hose, air filter side.
Photo 2 - Undo the bolt (1a) and remove the air filter assembly (1b).
Photo 3 - Remove the O-ring from the cold air intake pipe.
Refitting
- Fit a new O-ring on the cold air intake pipe.
- Place the air filter assembly in position and tighten the bolt.
- Tighten the band securing the air supply hose to the turbocharger, air filter side.
- Fit right front wheel arch liner
- Remove the vehicle from the lift.
Old 29-03-2009   #1
craggit has donated!
Angry Re: Bravo Air Filter Box Removal-Refitting
i cannot access and undo bolt 1A i dont know where to try and undo it its stuck solid
craggit is offline Reply With Quote Quote
Old 23-04-2009   #2
Penetrating oil and soak it overnight?
The Quest for Singletrack is Endless
DickBarton is offline Reply With Quote Quote
Old 30-07-2009   #3
Cyprus
OMG why do we have to remove our wheel its just an air filter
miketjet is offline Reply With Quote Quote
Old 18-09-2009   #4
Quote Originally Posted by miketjet View Post
Don't need to, you can just un-do the two (or three?) clips from the bottom then slide the filter out from the bottom. O, hand on, its for the 1.4Tjet, mine is 1.9Mjet.....
STILO NEWBIE is offline Reply With Quote Quote
Old 19-01-2014   #5
I have Bravo 1.4 90HP 2009 petrol and was hoping i could do this at home tomorrow.
Is it true that i need a lift to replace the air filter and a new o ring?
Air filter is usually easy on cars ive had in the past.
birdman99 is offline Reply With Quote Quote
Old 26-02-2014   #6
Ireland
Hi, I have a 2007 Bravo t-jet, we took it in to the garage recently for brakes, oil/filter and air filter, since we did it has been juddering under accileration, I was told a rear wheel had a buckel in it so we had them checked and one fixed, but problem still the same. we think it is a problem with new air filter, as it was not there before.
Any Suggestions Please !
andylite is offline Reply With Quote Quote
Old 30-12-2015   #7
If you jack up the vehicle slightly as if changing a flat tyre, remove the drivers side wheel, you can remove a few screws in the wheel arch liner and then un do 3 bolts on the bottom of the air filter housing and drop it out from the bottom. Saves having to undo the turbo piping as those jubilee type clips can be a right pain to get back on
Likes vkorras liked this post
Typer000 is offline Reply With Quote Quote
Old 2 Weeks Ago   #8
South Africa
The clip number 1, what do you use to remove and can you put it back when you do?
Dylan Latz is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.2 SX Air Filter Box/Grille Query sean.round Bravo / Brava 6 15-12-2008 23:51
(G) What is the box under the air filter mikelotus Stilo 1 14-09-2008 12:40
(G) Air filter box nigel_bytes Punto (Mk2/2b) 0 10-05-2007 20:46
