Hi
Anyone know if its possible to get to the water pump without removing the engine on a HGT?
thanks
thanks Ozric-Al thats good news, DIY job or a trip to the garage? couldnt see a guide on fiatboo for it.
cheers
you need to loosen off the engine mounts (while supporting engine) and shift the engine over a few inches to get enough clearance to get the waterpump off.
i havent done this myself, but i know its not for the faint hearted.
water pump bearing failure can happen in 2 different ways, seizing or collapse. collapse is very nasty, very rare, and obviously not an issue here. when the bearing starts to seize you get a constant whining from it, which is usually worse when hot, and increases in pitch and volume with the rpm. the noise indicates excess friction in the bearing which means excess heat will also be occuring. if the bearing overheats too much it collapses. i'm already praying that wont happen but if you suddenly notice a change in the noise be afraid. when the bearing collapses the timing belt can go slack and slip or catch on something and snap. not good.
stick a bot of hosepipe in your ear, and hold the other end near each pulley in turn with engine running. you will then be able to pinpoint the noise (with a bit of luck)
Loving that!
Besty - when was your last cambelt change? may be best to get the lot done at the same time to be sure. tbh, the HGT does have a high pitch noise as standard. Everyone that has one says the same. I had cambelt with water pump change 40k ago and the noise was exactly the same after and every HGT I've heard is the same.
My cambelt was changed at 53k about a month ago, its not a very loud noise if ive got the heater going i cant hear it so i guess im gonna leave it and worry about it if it gets louder and no i didnt get the water pump done and the same time and yes im regretting that now
Ozric - I might have to see if that offer extends to me at Brooklands because I would like to put my mind at ease.
Can a pas tensioner etc be changed without a full cambelt change? ive had that done twice in the past year and i cant justify the outlay despite the fact that i love the car!
