Thread Tools
Old 09-04-2004   #1
fiat bravo airbag light
the air bag on my fiat bravo has come on and will not go off. i took it to a fait dealer and they said it will cost 423 to have it fixed it needs a new ecu and two loops???????? for one little light. does any one know how to turn this light of and will it pass its mot with it on.....they said the ecu unit is not made anymore for my p reg model and needs the two loops........[:(!][:(!][:(!][:(!]
wendy is offline Reply With Quote Quote
Old 10-04-2004   #2
polecat has donated!
Hi and welcome to the forum.:D
I would ask them, or another dealer, if they can reset the fault first. If the fault won't reset then check the wiring. The passenger side airbag wiring is quite often installed and causes problems even if the pass airbag is not fitted.
Otherwise check round some scrappy's for one. Anything but a new ECU.
Not sure how they check the airbag on MOT's, pulling the bulb out might work?
Good luck and let us know how you get on. Keep checking in, you may get more useful info off another member.
polecat is offline Reply With Quote Quote
Old 18-04-2004   #3
Fiat dealer will re-set it for 25. Had mine re-set and was fine for a while, but light is back on again, been through an m.o.t since and wasn't even mentioned. think the only answer is to take bulb out.
maj is offline Reply With Quote Quote
Thread Tools
(G) Fan of Fiat Bravo! Mikele011 Bravo / Brava 10 29-08-2007 12:14
Discounted Tuning @ Fiat Forum Day alfanige Lets Talk FIAT 45 17-01-2006 15:03
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 22:38
(G) Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 05:30
