Hi. I'm posting this on behalf of a friend who's asked me for help with her car. It's a W-reg (2000?) 1.2 SX 16v, and it won't start from cold without a lot of help. It basically seems like it's refusing to acknowledge that the car is cold, and trying to run it as if it was already hot. It starts if you give it some throttle, but as soon as you lift off, it splutters and dies. Once you get it warm (by manually adjusting the idle speed), it's fine.
It started after the car overheated & boiled over in traffic a week or so ago. The coolant has been refilled & bled and a gas test has been done to check the head gasket is OK. I left it idling a while ago and it overheated again because the fan failed to come on. I was wondering if the same sensor that monitors the engine temperature also activates the fan?
Some things that I have noticed (and rectified), bearing in mind that I had never seen the car before it overheated:
1. the throttle cable adjuster lock nut was loose (even after the RAC adjusted the idle too high in order to get the car running). I've re-set the idle to about 850 rpm when hot.
2. the throttle cable was not fixed into it's clip a few inches below the air intake pipe. I've clipped it in place.
3. the throttle cable outer is broken where the metal bent pipe meets the plastic bits. I've glued this, and strapped the cable so it holds it sort-of in place.
4. I think the fan fuse was missing. On the upper block of fuses, the third fuse in the right hand column wasn't there. I've put a 10A fuse in (I know it should be 7.5A, but I don't have any). Trouble is, I can't get the engine warm enough to get the fan to kick in anyway - it doesn't seem to want to overheat any more!! For this reason, I don't know if I've fixed the fan or not!
I've checked that there's a spark when I'm cranking from cold, and the injector light goes out before I crank & doesn't come back on. The fuel pump seems a little noisy to me, but I don't know fiats, so it could be normal. I've run it with the air intake disconnected from the filter as well, to ensure the filter isn't blocked.
I've also reset the ECU (disconnected battery for 45 mins) and then let it idle for 5 minutes before switching off & on again. I'll find out in the morning if this has fixed everything.
Does anyone have any suggestions as to what is wrong?
