Technical New Brava, cigarette lighter not working
DrGonzo
Hi again, Another issue i noticed, went to test cigar lighter, pressed it in, remains stuck in, doesnt heat up, had to pull it out with firm tug, anyone got the know how on repairing these?
Oh, and I'm new here, howdy all :p
If you got a voltmeter test it. Its probably the lighter itself thats knackered.
another electrical fault! that could also be the cause of the noise you described in the other thread (although locking if far more likely).
check the fuse for the lighter, check there is power and earth at the wires, and if it all checks out then replace it with a scrapyard part.
ill be replacing lighter now as electrician said its bust, but current is ok in it's holder, so still not sure about the whirring noise i mentioned in the other thread
