Ok so fitting my Pollys tonight, now however didnt do the part about changing the levelers over from my old lights:
"2a. Connecting your headlight motors to your new Marea Headlights, this needs to be done correctly otherwise once they're on the car its difficult to do again.
2b. Above the main connector you'll see a small 10p size hole, with a white circular connector inside. Using pliers, pinch one of the spines and pull on it gently till it starts to rise and doesn't go any further, this makes the inner workings of the lights tilt up.
2c. You must prevent the white circular connector to move so the best option is to remove the covers for the bulbs and put your finger inside the area where you put the dipped light bulb in and wedge it in so that any pressure put on the white connector will not create the lights to tilt within the unit.
2d. This is where you'll need to attach the motor. The white prong sticking out of the motor needs to be placed into the white connector, it needs to be slid in from the top and then twisted on. Don't forget to put the spring back over the white prong sticking out off your headlight motor. To find out whether its connected properly gently try to push the internal workings of the light with your finger, if it moves its not connected, it needs to be firm."
Ok so didnt do all that, but do i need too? Lights are tilting up and down with the motor already on it.
I did instead, connect put up to 3 and down to 0, disconnect put up to 3, recconect put down to 0 then disscounect and put to 3 then recconect then down to 0.
But didnt seem to change during the sequence. But went up and down with the other and leveler works ok, just worried it might be pointing too low or something as i didnt follow the above. (as didnt have it with me at the time) Taking it out and following the advise isnt a problem, as only one fitted so far.
Advise needed urgent as doing the other one tomorrow.
