roseyp
- Dec 11, 2006
- 13
- 6
Hi All,
I have a 1995 Bravo, 1.4. Recently on setting of in 1st gear the car shakes and vibrates violently. I first though this was clutch judder, but if you set of in 2nd it does not happen, nor in reverse. I can select all gears fine and once moving the problem does not occur again.
The gearbox is the linkage (rod) type, and all of these seem fine. I am going to bleed the actuator tomorrow to eliminate this, but does anyone have any suggestions on the possible cause or the problem. There is plenty of fluid in the resevoir
Roseyp
Roseyp
