Im going to change the spark plugs on my bravo hgt this weekend, and all I need to know is where are the plugs located and are they easy to get to? Thanks
remove the sparkplug cover (torx bolts) its the big plate on top of the engine.
you will see 5 coils. under each coil is a sparkplug. to remove a coil you need to remove the 2 bolts on it, disconnect the wiring harness, then give it a good pull.
now remove the sparkplug using a plug spanner (make sure the rubber ring is in place to lift the plug out with) if you dont have a plug spanner with a rubber ring inside, you can use a coil to grip a plug and pull it out once it is unscrewed.
