Technical Help needed!
sten25
Estonia.
I have Fiat Brava 1,6; 76 kw; 1997
What is the correct name of the part in english?
The part is shown on pictures:
http://www.zone.ee/zonepunktee/sten
Also I want some information who sells it and how to get it?!
Can it be fixed if its not working properly?
That is the engine idle speed actuator. I'm not sure if it can be serviced but it looks like someone has had a go.
Do a web search on vehicle breakers or vehicle dismantlers and you may get lucky with a cheap component.
Good luck and let us know how you get on.:D
Is there any difference between 1,6 and 1,8 engine idle speed actuator? Can I use engine 1,8 actuator for my 1,6 engine?
