Last friday my ABS warning lght started coming on & off intermitently this problem got worse on Monday when the brake warning light came on and i lost all pressure under the brake pedal. A look at the fluid bottle quickly pointed the problem at a loss of brake fluid.
As i could not find the leak in any obviouse place i took the motor to the garage who said that 3 brake lines were holed and another wasn't far off. I got the 3 fixed but could not afford to get the fourth done:I. ANy way the lights all went of until i had travelled about 10 miles then the ABS light came on again.
I have checked the level of the brake fluid which is full (as in above the max line, full to the brim almost).
Why is the ABS light on now i can only think its either due to the bottle bieng over filled or the brakes need bleeding some more./
Please help, need to get this sorted asap.
Q TOY
Quickness Its A State of Mind™
Q TOY
