Old 18-10-2006   #1
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Coupe steering wheel on a bravo?!
Thats right, i'm bored with life so i thought to myself, what can i do thats original, difficult, affordable, wont chav my car, and maintains my theme of original fiat parts.
then it came to me. a fiat coupe leather steering wheel! they're sexy enough to make it worth while, and i bet i'll be the only one with one.
so i've bought it and attempted to fit it last night. its not as easy as i thought, no where near, but its possible.
the problems are:
1. the bravo shaft (too wide) wont fit into the coupe steering wheel
2. the horn wiring is completely different (earths through shaft on coupe)
3. the airbag wiring is different (not even similar)
4. the indicator cancelling system is different (not even on same planet)
5. the part used for 2,3&4 on the bravo needs to be modifed (destroyed) to allow the wheel to fit on the shaft, if it can actually fit on the shaft.
so what am i going to do about it?
well i've measured up the pipe in the centre of the coupe wheel, i think if i grind about half an inch off the back of it and i'm having a lucky day it should physically fit onto the bravo shaft. the spline pattern is the same on both, but the shaft is slightly wider on the bravo than the coupe so it wont push on all the way, or even half way, so i need to trim everything off the wheel except the splined part. this will have no impact on safety as it is only the splined part that is used to secure the wheel.
i've decide the airbag wiring is irrelevant because i had it disabled anyway. so i'm leaving the airbag disconnected. hooray for that!
however i'd like to have a horn (kind of useful at rush hour), so i'm going to determine where the live for the horn comes from on the bravo. it looks like a metal contact behind the magical part mentioned in 5. then i'm hoping i can still earth through the shaft as it does on the coupe, failing that i'll be able to earth it somehow by magic, using enoughn wire to allow full rotation fo the wheel. either way i'm not worried.
then there's the indicator cancelling system. this is probably the hardest part. on the bravo there is a big round plastic part that is connected to the sttering wheel and turns with it. the way it connects to the wheel is with 2 big plastic lugs at 3o'clock and 8o'clock. the coupe wheel only has a hole at 12oclock, and it isnt big enough to fit either lug in. so i'm going to remove both lugs and then drill a hole to fit a new one at 12o'clock on the round plastic part, then hopefully that will pit on the hole on the steering wheel and work in the same way it did. if this fails i'll just take the part off, stamp on it, then live without indicators that cancel themselves until i can make a part to do the job.
that shoud do it. i expect it will be all done tonight if i'm lucky, or definately by the weekend. pics to follow.....
and for anyone who's considering the conversion, dont do it, i think a mk2 punto sporting wheel is better looking, nicer to hold, and easier to fit
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 18-10-2006   #2
Here to help
bridges's Avatar
bridges has donated!
Re: Coupe steering wheel on a bravo?!
You have suprised me with that... I thought they would have been a straight swap.
must admit the coupe steering wheel is nice, its the the thing I prefer over the HGT when I take the my coupe out I love the feel of the Steering wheel and gear knob, (oooooooo,er ) the HGT wheel is thinner and the stock gear knob is terrible
Good luck with your conversion mate.
bridges is offline Reply With Quote Quote
Old 18-10-2006   #3
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Quote Originally Posted by bridges
i know, i still cant believe they used that gear knob, even a cinq deserves better.
i've stuck a new corolla knob on mine, its perfect
Old 20-10-2006   #4
jug
jug's Avatar
Trader Rating: 1
jug has donated!
well its with much regret that i can confirm that a coupe steering wheel CAN NOT fit on a bravo steering column. the diameter is different. even my grinder's best efforts and the destruction of my airbag, horn and indicator circuitry is not enough.
i now know a barchetta wheel will fit, so i'm hunting for one. but i doubt i'll find one until the day after i sell my car.
i think a mk2 punto sporting one will fit too, so maybe there's a chance i'll do that soon.
guess i'll have to sell the coupe wheel now
Old 24-10-2006   #5
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Oh dear Is the one in the HLX the same as the rubbery sx one? What's the Punto wheel like? Can't picture it off the top of my head.
Helz is offline Reply With Quote Quote
Old 24-10-2006   #6
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Get yourselves a Marea leather wheel
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 24-10-2006   #7
Trader Rating: 16
beau has donated!
will the punto one not fit? im sure its the same as the coupe but where it bolts on might be different? lol
be clever and see what other fiats use the same momo boss kit as the bravo and then see what steering wheels them models have and see if any you like pretty simple
Maserati 3200 GT Coupe
beau is offline Reply With Quote Quote
Old 30-10-2006   #8
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Quote Originally Posted by beau_4076
thats what i did, apparently the OMP boss kit fits many models, including the coupe, which is why i bought a coupe steering wheel. i now realise the listing for the OMP boss kit was indicating which models a boss kit is available for, not all the models that use only 1 boss kit.
but now that i know for certain that a mk2 punto sporting wheel will fit i'm after one of them, well actually i'm after a mint condition one for my girlfriend's mk2 sporting, then i can have her slightly worn one for cheap. bloody women !
the HLX wheel is much better than the SX one, but its still plastic and a bit cheap and nifty, i feel the need for some leather.
a leather marea wheel will do nicely now that you mention it hellcat
and it'll be easier to find
(G) How many bravo/as? sammiboo Bravo / Brava 255 28-02-2008 22:34
