Thread Tools
Old 14-10-2006   #1
Italy
Brava JTD105 OBD Socket
Does anyone tell me if my Brava 1.9 JTD (1999) has
a standard 16 pin OnBoardDiagnostic Socket?
I was looking for it under Steering Weel, driver side
fusebox, front passenger side dashboard...
but not found. Under the steering weel, upside the
bonnet release, there's a little black box signed
"bosch". I can't open it (and i suppose it's the
Fiat CODE box).
I've found something similar near the JTD engine
(dashboard right side) attached to the fuse box;
it's a 3 pin connector, the FiatTester I suppose.
I've bought a commercial OBD reader for LaptopPC,
but I'can plug it into my car
Please, help!
Thank you in advance.
CicoJTD
CicoJTD is offline Reply With Quote Quote
Old 14-10-2006   #2
Trader Rating: 1
JoskeJTD has donated!
Re: Brava JTD105 OBD Socket
Quote Originally Posted by CicoJTD
Fiat CODE box).
Please, help!
CicoJTD
On my Fiat Bravo JTD100 its under the steering wheel near the sound proofing. It has a plastic cap cover over it. Flick it off and it should be there.
The JTD105 should be the same as my JTD100. If its definately not there, try the engine bay near the fuse box near the battery.
JoskeJTD is offline Reply With Quote Quote
Old 15-10-2006   #3
Italy
I've just looked around steering wheel as you said. Near the sound proofing, i've the incar fuse box how you can see in this shoot:
Under the steering wheel, near the driver port I can only see the fuel inertial switch, as you can see there:
Exactly under the steering wheel, near the bonnet release, I can only see
these:
and
as you can see above, there's a little plastic box marked "bosch":
I suppose that is the FiatCODE for KeyCODE security check.
Well, at the end, I found the FiatTEST socket into the engine bay,
a 3 pole connector attached to the fuse box covered with a black
plastic cap, here is in red:
Can you show me, using these photos, where is the OBD 16 pin
connector you have on the great Bravo JTD?
Thank you again for your nice support.
CicoJTD
Old 16-10-2006   #4
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
you can attach the 16pin connector to the 3 pin connector, there are adapters you can buy to do it, but in the past i've just used a few lengths of wire to do it. can't remember which pins on the 16pin connector to use, but i'll find out.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 16-10-2006   #5
Trader Rating: 1
CicoJTD i assume your car isn't UK spec as your drivers side fuse box is on the wrong side. However i've managed to take some pics of my ODB port. Obviously the third pic will need to be flipped horizontally for a Left Hand Drive car.
Pic1
Pic2
Pic3
Hope this helps
Old 16-10-2006   #6
Italy
Thank you so much JoskeJTD, you're a great man! :-)
You're right, Italian version of Bravo/a JTD is left hand
driving. I didn't see any felt cutting under my driver
fuse box, tomorrow morning I'll try to have a better
looking: the dark out there doesn't let me check.
Anyway, I'll open an "hole" using a cutter, and...
we will see! :-D
Old 16-10-2006   #7
Trader Rating: 1
we will see! :-D
Dont bother cutting the felt, press the middle of those round plastic lugs and just remove the felt.
Old 17-10-2006   #8
Italy
I'm deprived of hope... :-( I've removed the felt as you said, simply and quickly, but behind there's nothing! I'll post as soon as possible some pics to show the problem I'm dealing with.
Thank you, again JoskeJTD.
Old 18-10-2006   #9
Trader Rating: 1
Ok i've been told that the ODB port can be found in the engine bay on the JTD105, Back left, its clipped ontop of a hose.
Old 18-10-2006   #10
Trader Rating: 1
Okay here is the ODB for the JTD105. Its not the same plug as mine.
Old 19-10-2006   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
Theres also one for ABS if fitted & one inside car for airbag.
Old 19-10-2006   #12
Italy
Oh well, thank you guys... I suppose I'll never plug my 16 pin OBD connector on that 3 pole socket, without any converter/adapter. I'm wrong?
Old 19-10-2006   #13
jug
jug's Avatar
Trader Rating: 1
jug has donated!
OBD Connector Pinout:
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 7 - K Line
Pin 16 - Battery Power (+12v)
pins 4, 5, 7, will be directly connected to the 3 pin connector on the car using some wire. the interface will need a +12v, normally supplied by the OBD connector, but it's not there on the 3 pin connector so you need to run a seperate cable from your 16 pin connector (pin16) to the battery positive terminal.
Old 20-10-2006   #14
Italy
Oh! Fantastic!!! Can you more exactly specify the corrispondence beetween Standard16pin OBD connector pinout and Fiat 3pin pinout???
It should be useful having a schematic...
Old 20-10-2006   #15
Italy
Well, I verified... Brava 1.9 JTD105 has not a standard 16pin OBD socket; it has 3 diagnostic sockets inside the engine bay:
1) As showed by JoskeJTD, here is the "injection diagnostic socket"
2) Here is instead the "A.B.S. diagnostic socket"
3) Near the connector shown above, it should be another similar socket
for "TheftAlarm diagnostic socket" (is not present on my car).
It's not all. Inside the car there are other sockets like those, at least one for the "Airbag diagnosis" an Clima (both next to the frontside smoking box).
I have to identify the 3 pole socket's pins in order to connect it to the OBD diagnosis plug. Just waiting for a convertion schematic
Thank you guys.
Thread Tools
(T) OBD Socket Tim T Stilo 5 19-07-2006 20:00
(G) Does a 2001 Brava have an OBD Socket? ciddy Bravo / Brava 8 14-06-2006 09:27
(T) brava JTD105 keeps cutting out spudjjfc Bravo / Brava 10 09-09-2005 02:39
(T) Brava 18. 115 ELX diagnostic socket PhilWalker Bravo / Brava 1 11-08-2005 22:56
(G) 2nd Hand Brava SergiuRO Bravo / Brava 4 24-04-2005 09:28
