B bajeknight New member Joined Aug 2, 2006 Messages 113 Points 26 Oct 9, 2006 #1 the horn on my brava is stuck, what can i do to fix it
Fast Finger Established member Joined Jun 2, 2005 Messages 1,058 Points 288 Location Hartlepool Oct 9, 2006 #2 Stuck on or off? Its most likely a switch problem. Check if its both if its dual horns. The check any relays if it uses them. Next thing would be to check the switches/buttons. Starting with the one you use the most often.
