Styling HGT skirts - how to fit?
LeeP
I've just acquired a pair of HGT skirts for my mk2 SX and obviously now need to fit them. From the look of it i've got to drill holes along my sills and rear 1/4 panels as the skirts are clipped in place with some large red plastic plugs. Also, they were fixed along the bottom edge to the sills too, under the car. My car has plastic blanking plugs blocking the holes but when i've removed these plugs there are no captive nuts or anything attached to the sills, are they just fixed in place by these plastic plugs or are they normally bolted to the sill?
I bought the skirts mail order so never got to see how they were attached to the car they came from. If i do have to drill the upper sills and quarter panels, anyone have the measurements of exactly where to drill??
Thanks, Lee:devil:
Thanks, Lee:devil:
To get these to fit you have to modify the front of them to fit a non - HGT because the HGT has wider slightly more flared wheel arches. I bought a set of these thinking they would bolt straight on but they don't. Dont get me wrong they will go on it just takes some trimming.Here is a pic of mine with them on
worth the effort though eh??(y)
Thanks Bridges - they're the same skirts so would appreciate any info regarding how they fit or what they're fitted with! Your car looks good, just bought my step-son an SX in the same colour which needs some work too, gave 30 quid for it! the best colour a Bravo comes in I think. I don't suppose you're thinking of getting rid of those alloys by any chance!!??(y)
Thanks for your nice comment.
Am afraid they are now on my 20v coupe :) but they do look nice on the bravo. The Bravo is now on my Coupe wheels which suit it nicely.
http://s53.photobucket.com/albums/g...current=101004.jpg&refPage=&imgAnch=imgAnch13
Bravo boy is right. The HGt front end is different. It is actually a Marea. The wings are Marea wings and are different. It needed the wider front chassis to fit the lovely 5cylinder 20v.
Will look in the morning. :)
i wouldn't drill anything, a good adhesive will be better. drilled holes will rust, then the skirt will drop off once the rust has weakened it, leaving a very messy car. i've fitted skirts using adhesive more than once with no problems
http://s53.photobucket.com/albums/g60/Mr_Bridges/?action=view&current=101004.jpg&refPage=&imgAnch=imgAnch13
Chassis isn't any wider apparantly - just the front track is wider to allow enough space to turn the wheels :rolleyes: Well that's what I've heard, although something must be wider and I don't think its the lower arms.
Don't forget the bumper too! It's Marea width although not a Marea bumper.. Marea have massive wide mouths, bravo/a have holes where needed.
true, the hgt has slightly longer driveshafts (and other differences) which makes the wheels stick out a little bit more, but the chassis is the same.
I will check the chassis as am curious, I know the Bravo wings will not fit the HGT so something must be different somewhere :cool:
I have sat here a (W reg Brava auto 1.6)
(V reg Marea Weekend 105JTD) (R reg Bravo HGT) and a (R reg coupe 20v)
girlfriend now has the HGT (y)
the bravo wings will fit the hgt, they are a different size but they still fit, they wont meet the hgt bumper correctly, but you can change that too. thats why its so easy to do an hgt conversion on the front of a bravo, you just replace the wings and bumper, nothing else is needed.
jug said:
thanks. i wish i had the 5th cylinder, but my bank balance is pleased i dont. :D
My 5th cylinder and bank account are best of friends since they were introduced through the Diesel pump :D
Bank account and Tipo are not so happy together :(
Edit - Really thinking about it the lower arms are the same length and the chassis is the same - what is wider is the sub-frame/engine-mount. Wider track makes for a huge turning circle. 10m for the 105 marea and 11.5m for the 130!
Cheers Bridges
Fixings I'm mainly interested in are the ones under the sills, from other replies i think it'll be best to stick them on rather than drill my upper sills and rear quarters but i'd still like to secure them in the factory way along the bottoms.
Lee
:devil:
Under the sills there are about 6 bolts. The bravo skirts have indents underneath these should be present on your new skirts. I will post some pics,
they are also fixed at each end on the flat surface that forms the lower part of the wheel arch. If you screw them to your sills it will help hold them whilst the sealent adhesive (Tiger Seal) goes off, otherwise use G clamps etc. then use a sealant around the holes this will prevent water ingress. As Jug says very poorly fitted skirts (bodged) attempts can lead to unprimed metal and this is where it will rust. I always spray my inner sills internally with oil as well as chassis box sections.
sorry for the late reply have been on my Coupe as the clutch exploded and getting the gearbox out was time consuming.
