oh right, so you cant select any gear with the engine running. i get it now, its the slave cylinder, happens all the time. remove the battery to see if its leaked, or even easier check the brake fluid reservoir, if its low it means the slave cylinder is leaking. easy to replace (less than an hour) and cheap to buy (£19.99 @ motorfactors)
