FIAT Auto Specialist Team
Old 11-09-2006   #1
Electric N/S window not working
Hi everyone
New to all this.
My Brava has an electric window that won't go down with any switch. I have metred the switch which has power and switches with power, but at the motor the power comes up to 12v then drops to 0v straight away, The motor Would be greatful of any HELP.
jep73 is offline Reply With Quote Quote
Old 11-09-2006   #2
Falcon_II has donated!
Lightbulb Re: Electric N/S window not working
Disconnect the window from the motor then try it. If you can try the drivers window motor on the wiring. cos it sounds to me like the motor is trying to ppush and thinking the window is all the way up.
Falcon_II is offline Reply With Quote Quote
Old 11-09-2006   #3
Hi
Thanks for the reply.
I have metred the power with the plug off the motor.
Old 11-09-2006   #4
the motor will more then likly provide a resistance (Load) until the window is up then the car stops winding the window up. the motor off will tell the car the window has stopped. it needs a load.
Otherwise you could burn the motor out. it only takes a small load to tell the motor to tell the car to stop sending electric.
In simple terms.
Old 12-09-2006   #5
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
power the motor directly using a live and earth from the battery, switch the live and earth round to change between up and down. if it works like this then the problem is in the switch or wiring, and not the motor.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 21-09-2006   #6
Thanks for the replies. All fixed now, just undid the nut that hold the motor and the 2 along the window tried the switch and the window came down. cheap as chips.
(T) electric window Big Black Stilo Stilo 10 14-08-2006 23:21
(T) help need with electric window and c/locking dutch923 Marea 6 12-06-2006 22:27
(T) Electric window help plz daznjo Punto (Mk2/2b) 0 09-03-2006 19:59
Driver's side window Nudgeman Bodyshop 4 30-11-2005 13:37
(T) Electric window jambo Punto (Mk1) 7 09-08-2003 20:39
