Thread Tools
Old 02-09-2006   #1
High CO on Fiat Brava - Failed MOT
new, hoping someone can help. I took my Brava P plate for it's MOT and it failedonthe CO only, but the readings where high. could anyone give advice as too what i should do to reduce them. the readings where
fast idle - CO 2.71% , HC 105ppm, Lambda 0.98
sec fastidle - CO 1.59% , HC 64ppm , Lambda 1.00
Natural Idle - CO 1.26%
Hope this helps and thanks for any replies
geonuk is offline Reply With Quote Quote
Old 02-09-2006   #2
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: High CO on Fiat Brava - Failed MOT
I've had a look about and high CO seems to suggest the CAT needs replacing.
Sorry
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 02-09-2006   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Yes High CO is lambda sensor or cat.
Lambda is cheap and easy to change. You takes your choice
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 02-09-2006   #4
zombie nation
Hellcat's Avatar
Trader Rating: 3
To bump it through this year you could try the old red-ex and thrash technique? Might be enough to get it through this year and gives you time to get the parts changed in prep for next year.
Old 02-09-2006   #5
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Quote Originally Posted by Deckchair5
I'd go with trying that first, it happened to me last year and after a change and driving for a few days, all was good and passed fine. Cats are costly and despite the damage I've done to mine (due to lots of exhaust problems), it still works fine so hopefully not that.
Helz is offline Reply With Quote Quote
Old 06-09-2006   #6
Had the same problem but the guy at the garage managed to get it through by testing it again after the car was hot. Had the CAT changed anyway and was much better but now have problem with the new CAT as its very noisy.
boycey9 is offline Reply With Quote Quote
Old 07-09-2006   #7
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
noisey as in rattling (in whihch case rip the heat shield off)
or noisey as in blowing / leaking (in which case slap whoever fitted it and get them to use exhaust paste this time)
and you are right, before every mot you should get the car nice and hot, give it a good long hard drive. also add a bottle of an emissions reducing additive, they actually work
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Thread Tools
FAO Bushboy Steven Leisure Lounge 13 25-07-2006 11:41
(G) Fiat Gingo Sonic74205 Panda 11 29-11-2005 15:05
Fiat group CEO Sergio Marchionne By Luca Ciferri; Automotive News Europe/November 14! J333EVO Lets Talk FIAT 8 22-11-2005 19:23
(G) Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 05:30
