General does a bravo sx 100 16v have air con ?
No, I had one. Good car, but no air con. You might want to find out if it can be retro-fitted though. It could cost a bit.
Check out the Fiat Bravo guide and look at 'The Model Range' under contents, and in particular; the model range for Series 2 - 98-01.
There you will find all of the standard equipment.
If you are buying go for the 115 16V, it will save any cost of getting it fitted!
as said, some do some dont, you have to keep your eyes peeled for one with air con as its not a comon option im afraid. the same goes for the rest of the range tbh, air con is more common in HGT's and 1.8 hlx's and hlx JTD's, but it does come up in the lower models. if you keep an eye out for a hlx you will stand a better chhance than the sx's
