Thread Tools
Old 30-01-2004   #1
*HELP* Track rod removal
Had a bit of an encounter with the kerb in the ice yesterday and it's bent the n/side track rod.
Now how the f@*k does it come out! I've managed(eventually!) to get the track rod end out...damn those taper fits...but at the other end, the steering rack end there's a ball and socket joint.
Anyone know how to get this apart? I want to see if it's possible to straighten it slightly then reset the tracking, failing that replace it. I rang fiat, and the track rod is available as a spare part(@ 45!) so it must come out somehow? Does the track rod come with this joint already installed and i have to fit it at the rack?
HEEEEEEELLLLLLLLP!
Ali P is offline Reply With Quote Quote
Old 31-01-2004   #2
polecat has donated!
Hi and welcome to the forum:D
If you look along from the ball and socket joint towards the bellows you will see that there is a lock nut and a threaded bar. You loosen the lock nut and then unscrew the ball joint assembly off the tie rod. Count the number of turns so you don't change your tracking.
Fix the bend and then screw it back on counting the turns again. If you get a new one and fit that by counting the turns you should have the same tracking again.
.....Oh you would still be advised to get the tracking checked again at some point:).....
Dave. :)
Marea HLX 2.0 20v
<h6>FIATcentral window sticker, silver poppy coral, titanium tax disc.
:)Blue Momo Tomahawk Gear Knob :)
Blue gaiters, Blue sidelights, Blue interior lights, Blue lacquer on engine, feeling blue ;)
Ecotek fitted, removed and waiting for warm weather
So much to do, so little time.... and Totally Skint!! :(</h6>
polecat is offline Reply With Quote Quote
Old 08-08-2010   #3
josize has donated!
Re: *HELP* Track rod removal
i have got the same problem but my hub is not attached to the track rod and so the rod turns as i try and undo that nut.....any advise of how i could losen it off easily????
josize is offline Reply With Quote Quote
Old 10-08-2010   #4
fiat_-_bravo has donated!
Quote Originally Posted by josize View Post
Clamp some mole grips to the rod to hold to stop the rod from turning as you undo
fiat_-_bravo is offline Reply With Quote Quote
Thread Tools
(G) For Turbo owners: Track control arm clamps! Morty Mort Uno 6 19-08-2004 18:03
(T) Track rod end arseofbox Cinquecento / Seicento 18 22-07-2004 23:20
Track Car James M Leisure Lounge 2 28-01-2004 22:57
CCC Track day report CentoEvo Events 4 30-04-2003 18:52
15th June Track Day 2.0 20v Events 0 07-06-2002 20:02
