Hi
All help would be much appreciated.I have a fiat bravo 1997 td been having problems recently where the key code light wont go off and engine wont start have been using red key for daily use found out about a week ago shouldnt use the red key so have had blue keys cut as car didnt come with any so i try to program the blue keys in the ignition as detailed on this forum.So i put the red key in switch ignition on key code light goes out remove red key put blue key in but key code light stays on i have tried this many times and all that happens is when you get to the blue key the light just stays on.I dont know what to do now.
thanks
thanks
