Old 21-05-2006   #1
Rear Wiper Wash
Again the rear wiper washer problem, so I fixed it but no spray from the pipe. I checked over and over again and found that the wash liquid is not reaching the wiper arm but leaking from the bottom of the car on the driver side. Is there any way to fix this pipe leakage?
neoseal is offline Reply With Quote Quote
Old 21-05-2006   #2
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Re: Rear Wiper Wash
Leaking from the engine bay or the back?
Helz is offline Reply With Quote Quote
Old 21-05-2006   #3
Former FIAT Obsessive
Rich's Avatar
Trader Rating: 1
Rich has donated!
Re: Rear Wiper Wash
Sounds like it's leaking from the actual reservoir / pump, check the tube that comes out of the pump to make sure its all secure. Pipe tape might work or else it'll be pipe replacement; halfords sell generic or FIAT will do you the original pipework too.
Last FIAT: 08 Bravo TJet Sport, Maranello Red
Retrofitted: Blue & Me Nav, Chrome Handles
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Sister-in-Law's 58 GP 1.4 Eleganza, Azure Blue, Cimate, Parking Sensors
Previously: Mk.1 Punto, 2x Brava, Barchetta FL, 5x Stilo, Nuova Bravo, and more . . .
Rich is offline Reply With Quote Quote
Old 22-05-2006   #4
Re: Rear Wiper Wash
Its not from the reservoir or pump or engine bay. Its leaking from somewhere from bottom, below the driver and back seat. I think there is a pipe joint somewhere in the body on the bottom of the car and I want to know how to access that area.
Old 22-05-2006   #5
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: Rear Wiper Wash
I think the pipe runs through the car under the carpet and rear seat.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 22-05-2006   #6
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Rear Wiper Wash
your leak is coming from the releif valve, when the pipe is blocked the relief valve bleeds the pressure to prevent pump damage. the valve is located in the engine bay next to the fuse box cover, removing the cover and the water proof rubber lining behind it makes access easier. the valve is a black plastic parts which joins two pieces of pipe, one black and one white, the white pipe goes to the pump, the black goes to the rear washer. when you spray water and there is a blockage the water is released from this valve and finds its way down to the floor under the car making it difficult to locate. this is a common problem i've fixed a few times already. i would blow compressed air through the pipe (when its disconnected at both ends) and then remove the valve and replace it with a simple join pipe like you can buy at a pet shop for aquarium airpipe joining.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 22-05-2006   #7
Re: Rear Wiper Wash
Thanks jug, will see to it tomorrow. You know I went to the scrapy to see where the pipe runs thru, in those dismantled bravas, but coulnt make out. Thanks m8.
(G) Rear Wash Wipe keggers Ulysse 11 29-01-2010 10:51
(G) Rear Wiper Motor joeandkirsty Marea 1 09-08-2005 22:58
(T) S reg rear wiper blade retrocircles Punto (Mk2/2b) 2 19-05-2005 22:51
(T) REAR SCREEN WASH adnams82 Cinquecento / Seicento 1 15-08-2003 23:50
