if you bought headlights you have to remove them before you can fit new headlights, but i think you mean you bought headlight bulbs, in which case you dont need to remove the lights, you just remove the grey cover on the back of them, then pull the wire from the bulb, then release the bulb holder catch, then remove the bulb. as they say in haynes "refitting is a reversal of the removal procedure"
