Hi all
Since changing the exhaust on my 1999 Bravo 80sx 1.2 16valve i'v been havin probs with idlethey wouldnt go below 1500rpm and were jumping between 1500 & 2000 prm. I'v changed plugs , filter cleanded idle valve in throttle body reset ECU with no change. I then changed the LAMBDA sensor still no change. iv disconnected the idle actuator and gave it a clean put it back and now prm 2000 jumpin to 2500 so i took idle actuator of throttle body but left it connected to the loom I knew ther would be no idle but ther no jumping of revs so is it safe to assume that the IDLE ACTUATOR seems to be the source of my problems or does anybody have other ideas. I work for BOSCH and get my parts cheap i.e £55 for idle actuator :bang:
