Technical Brava 1600cc Brake fluid Loss????
kfz
Im losing brake fluid, problem is I dont know where from. Ive had the car up on the ramps and the the usual culprits like rear pistons seals, rubber brake line unions are all bone dry. Ive checked all the lines as best I can without removing covers etc and can find no damage or corrosion. The res looks ok too. Wheres the servo??
Needs topping up every week. Brakes feel fine, not spongy or weak???
What next
Kev
sorry maybe i should clarify, the hydraulic clutch uses fluid from the brake fluid reservoir. the slave cylinder is prone to leaking, although it could also be the master cylinder. if you remove the battery tray you can see the gearbox with the clutch slave cylinder on top. the most common point of leaking is there.
thankyou very much, you just saved me a whole pile of time.
will check it it out asap.
Kev
