Justin
This is my first post so forgive me if it goes pair shaped! Does anyone have an idea as to why this Brava, after working fine 30 mins earlier, has suddenly started to play up when it was restarted. It would idle quiet well before, but now it refuses to idle at all unless I use the accelerator to hold the revs above the usual idle speed. As soon as I take my foot off the accelerator the car dies. It will start up again ok, but unless I press the accelerator it will die again. When I try and hold the revs at around 2000rpm to keep the engine alive, the engine starts to over rev as if I have pressed the accelerator a lot harder.
I will be buying a haynes manual later to locate all the sensors ect that you guys may recommended I check. I'm quiet good under the bonnet, but have no experience of fuel injection systems. Any help no matter how technical would be a great help as it's going to be a nightmare if I have to drive this car all the way to the Fiat dealer.
Thanks, Justin
Thanks, Justin
