Technical Clutch Problem ? any ideas ?
Leaper
I'm having trouble selecting gears, especially first & reverse
I have had a look at the master cylinder and can not see any signs of any leaks, & have bled it with no luck
the symptoms are
Hard to engage gears & clashing in reverse, the clutch is only just disengaging at the bottom of the pedal travel.
There is no problem selecting the gears with the engine off, and no sign of any clutch slippage when in gear.
Any ideas of what could be causing it that i could check out before resorting to putting it in a garage would be appreciated.
