hay guys, i have asked in the Marea section but no one seems to know, so thought i'd give it a shot here, anyone know how to remove the foglamp and refit a replacment, i cant get the thing out...
iirc there are 2 13mm bolts that hold the frame in place under the front bumper, directly in line with the fog light set back (get the cars nose up in the air) and once thats undone there are 3 screws i think actually holding the fog light in from the back tothe front face of the front bumper from behind (so you have to get under the car and reach around)
hth, if not ill have a look at the fogs i have in the shed when i get home for you mate
There are three screws in total holding the foglight holder onto the bumper. If you look directly under the bumper under the side of the foglight, you will see two screws. Undo These. The third screw is inside the Foglight holder. You will need to look inside the foglight holder then look directly up. You cant miss them.
Once to remove the foglight holders, just unclip the wiring and there will be a further three smaller screws holding the foglight to the holder.
hmm... well pete told me to remove the inner plastic arch bit spent awhile getting that out then relised i just had to unto the two screws under the bumper, then remove it from the front of the bumper and swap lamps.
well its done now, just gotta add screenwash and take some piccies
