FIAT Auto Specialist Team
Old 09-12-2003   #1
windscreen washer direction
can anyone tell me how to adjust the direction that my front washers spray in? As they currently spray more of the car behind than mine
yoggod is offline Reply With Quote Quote
Old 09-12-2003   #2
yes if you get a needle and put it in where the water sprays out, you can move the ball that is inside to where erver you want it to sparay
morteza4321 is offline Reply With Quote Quote
Old 10-12-2003   #3
polecat has donated!
Check to see if there is a small hole in the side of the nozzle mounting. You can adjust the height with a screwdriver from there.
You need to direct the spray to about 250mm from the top of the windscreen.
85% of Marea HLX drivers have speeding tickets.... lol they'll have to catch me first.
polecat is offline Reply With Quote Quote
Old 14-12-2003   #4
bear in mind the force of air coming at the car at speed, it'll be diffeent to when the car's stopped. mine used to spray water through the sunroof
99 Brava 100 HSX with not enough mods
mad_colm is offline Reply With Quote Quote
(T) windscreen washer MartCinq Cinquecento / Seicento 8 01-12-2014 13:12
(T) windscreen washer problems svmurray Punto (Mk2/2b) 7 17-09-2004 16:44
(T) leak of windscreen washer bottle glg Punto (Mk2/2b) 3 02-02-2004 17:55
(G) Windscreen washer cap DotSPF Uno 6 30-10-2003 20:33
