can any 1 help my pass side elec window is so slow going up and down im sure it goes back wards,,is there any thing i can do to make it go faster like is should,,any help would be great ,,,
Try spraying silicon lube up the channels first. If that doesn't cure it then you need to take the door panel off and look at re-aliging the window mech or replacing the motor.
well i didnt have that i used a bit of wd40 ,,it goes down fast now but now goes even slower up..,,but thinking ya right door panel to come of,,is it a hard job to sort
No idea on the Bravo. Probably a few screws (in door handle and door tray) and then a load of clips. Got a haynes manual? They're usually good at the interior stuff.
well i try and have a go ,,lol if it goes wrong il be bac on,,,,,,thax m8 for ya help ,will now go and buy some silicon lube and try that to,,and wipe of that nasty wd40 lol
there are if i remember rightly two different sized allen bolts to remove as well as the screws. if the window appears to push backwards, then its up against resistence. as hellcat says, silicone spray is the answer or you can use dash spray[basically the same stuff].check the channels at the bottom for any crud. and make sure the surround channels are straight and clean before spraying.
