im Axle Specialists
Old 4 Weeks Ago   #1
Brava 1.2 obd location and alternator lead question
Hi All,
My 2001 1.2 Brava (Not Bravo) has an orange engine light on (But drives fine),
so I wanted to get a OBD2 checker for it. I expected to find a yellow 3 pin
socket by the fuse cover but there's nothing there. Where might it be?
Also, while digging about I noticed a two pin connector loose next to the
alternator. My guess would be that it was removed on purpose, any idea why that might have been done?
What does it do?
One more while I think about it, the passenger door latch split pin has broken, do I need to take the interior panel off to fit a new one?
Many thanks for any help.
Steve
Brim987 is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Re: Brava 1.2 obd location and alternator lead question
Quote Originally Posted by Brim987 View Post
Hi All,
What does it do?
Steve
https://www.outilsobdfacile.com/loca...d/Fiat-brava-1
jackwhoo is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
varesecrazy has donated!
Hi Steve
I put an OBD2 thread in the GUIDES
Charlie .. ex 2001 marea
Old 3 Weeks Ago   #4
Thanks for the reply Charlie.
I'd actually found that link googling previously but there's nothing there in my car.
Here's two pictures of the nothing there!
I've also added a pic of the alternator lead, if anyone knows what it does
or why it might have been unplugged I'd appreciate it.
The Haynes manual I bought for the car hasn't helped in the slightest on
any question I've had so far... Maybe it's me.
Steve
ID:	209922   Click image for larger version
Old 3 Weeks Ago   #5
Steve
If the switch is on your power steering pump it detects increased pressure in hoses when steering loaded. When switched on it increases idle speed slightly to stop stalling when manovering at slow speeds. Maybe switch stuck on and so disconnected. Don't worry about it .
Please post another pic of your engine bay with wider angle
Old 3 Weeks Ago   #6
I like the picture of nothing there (-:
But the link shows the area slightly left of centre of bulkhead and slightly higher up.
The second two photos in the link should be rotated 90 degrees clockwise.
Ignor ref to air intake-that's a mistranslation.
Please may I have another pic of nothing there too (:
Old 3 Weeks Ago   #7
Yes, it might be the power steering pump. Sorry, I'm no mechanic!
Here's some other pics.
ID:	209925   Click image for larger version
Old 3 Weeks Ago   #8
I can see your obd connector from here(-:
Well I can see the obd storage clip/cap can't see if actual plug and wire is attached or if it has dropped down.
Old 3 Weeks Ago   #9
The switch is a pressure switch for steering system .
Old 3 Weeks Ago   #10
Steve
Hi again
Im intrigued by the 2pics showing the fluid reservoir..
Alternator..pas.. seem to be near RH Headlamp
Your OBD PORT should be above the pedals in drivers footwell..
However.. we do have others on here periodically who are adamant their 2001 PETROLS are not OBD2..
Mine was a Diesel.. and a VERY well concealed plug ( and cap..)
Thanks jackwhoo thanked for this post
Likes jackwhoo liked this post
Old 3 Weeks Ago   #11
Quote Originally Posted by varesecrazy View Post
Hi again
I was thinking it should be obd2 also .
Maybe poster didn't look for multipin obd connector above feet?
Anyway storage clip/cap for previous generation connector is on side of fuse box in engine bay , passenger side near bulkhead not far from the gaffer taped air hose(-:
Can't see from photo if it has a wire stored in it, so maybe it has dropped out and now hanging down somewhere or maybe it is obd2 above feet in cabin.
If this is the fuse cover you refer to in your first post I apologise, there are fuses inside the car and that is what I thought you referred to.
Sometimes the obd connector is near the interior fuses.
Old 3 Weeks Ago   #12
Thanks to all for replies.
I can't see anything near/dropped by fuse box in engine bay.
I'll have a look above the pedals, I did see a bravo youtube video saying a panel needed
removing...
Old 3 Weeks Ago   #13
Where?, do tell..
Old 3 Weeks Ago   #14
Where?, do tell..
Storage clip is on the side of engine bay fuse box .
storage clip/cap for is on side of fuse box in engine bay , passenger side near bulkhead not far from the gaffer taped air hose(-:
Plus take lid off engine bay fuse box and look in there sometimes obd plug is in there
Old 3 Weeks Ago   #15
To open engine bay fuse cover push back clip in centre and lift left hand side
Thanks varesecrazy thanked for this post
(G) Obd location benjibj Ducato 1 27-01-2020 13:54
(G) OBD Connector Extension Lead. Davren Stilo 0 31-01-2012 16:22
(G) OBD II location pandaactiveeco Panda 17 24-08-2011 12:34
(T) Fiat OBD II USB Diagnostic Lead-punto s 60 apexuk Punto (Mk2/2b) 2 04-11-2010 11:49
Question about my Brava and OBD... Luca FIAT Boo Archives 8 08-06-2005 14:33
