Old 03-12-2005   #1
Another Slave Cylinder Prob, But how long b4 the clutch dies?
As in topic.
I was driving along a road not so far from home on thursday, adn the clutch suddenly dropped and stayed down, wouldnt come back up. i pulled up and pushed it up with my hand. after that it seemed fine again but just today and late friday it felt like the clutch pedal wasnt coming up all the way. i took it to garage and turns out slave cylinder leaking.
its booked in for monday afternoon to be replaced.
but i was just wondering is it safe to drive it monday morning to work and back to garage. it wont die on me on the way will it.
also is tehre anything else i should check as the salve is leaking , are there any other knock on effects.
bravo98 is offline Reply With Quote Quote
Old 03-12-2005   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: Another Slave Cylinder Prob, But how long b4 the clutch dies?
Well it'll be awkward to drive but won't do any harm short term if you can handle a disappearing clutch biting point.
Are you sure the clutch return spring hasn't just snapped or become detached?
Of course, make sure the clutch/brake master cylinder is topped up but the clutch take off point is higher so the clutch would stop working before the brakes would be affected. You can drive the car with no clutch at all but it's not much fun
Slave cylinder is a quick and easy job once you take the battery out
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 03-12-2005   #3
cant be spring snapping as clutch pedal still works, took 2 garage they said slave cylinders leaking.
Old 03-12-2005   #4
Deckchair5's Avatar
No not the clutch pressure plate springs
Theres a return spring on the clutch pedal which takes the weight of the pedal when not depressed. This regularly snaps........
If you have fluid loss on top of the gearbox then your slave cylinder is certainly gone but the pedal should still return so check if you have a clutch return spring on the pedal itself
Have a look here https://www.fiatforum.com/marea/2615-clutch-failure-marea-2-0-20v-elx.html
99 Bravo 1.2SX
Old 04-12-2005   #5
LooseCannon has donated!
I had this problem too with my bravo-had to keep pulling clutch up with my foot. I actually did this for a couple of days until someone had the chance to look at it, so you will def. be okay for work on monday
I had the injector replaced as i was told it was leaking too, and it's been fine since-that was a few months ago
"I've had a wonderful time, but this wasn't it."
LooseCannon is offline Reply With Quote Quote
Old 04-12-2005   #6
was yours a spring problem too. where do i look to see whether teh spring has snapped or not? what am i looking for
Old 04-12-2005   #7
i mean my pedal is coming back up. its just that one time on thursday when it stayed down while driving. after that it just felt slightly depressed. dont really know. hope its not a spring problem too.
Old 04-12-2005   #8
Deckchair5's Avatar
"i mean my pedal is coming back up. its just that one time on thursday when it stayed down while driving. after that it just felt slightly depressed".
It's probably just feeling a little down at this time of year
"where do i look to see whether the spring has snapped or not? what am i looking for"
Got a Haynes manual? Look under Brake pedal removal Section Section 9.13 illustration 11.3 Nice piccy there. Bog standard coiled spring attached to the clutch pedal. It may have broken or just become detached. Only 2 to buy and you've got to have that working to help you bleed the clutch after replacing the slave cylinder if you're going to
99 Bravo 1.2SX
Old 04-12-2005   #9
one last question. i havent a haynes manual, so when i go to garage ill get it checked. is the spring something that is rare to get hold of. as they had to order my slave cylinder for monday. i wont have to wait any longer for the spring will i.
Old 04-12-2005   #10
Deckchair5's Avatar
It's not rare in that most Fiat dealers should have one but if it's broken your garage will have to go and get one. Have a look and see if you can see it. Grub down and look up from where the pedals are; find the clutch pedal and where it pivots. Look for a spring about the size and shape of your forefinger.
Is it there? is it broken? is it just detached?
5 mins now could save 2 hour wait for parts
Put a Bravo Haynes manual on your Xmas wish list!
99 Bravo 1.2SX
Old 04-12-2005   #11
Quote Originally Posted by Deckchair5
will do. looked at the clutch just now. the spring is shiny silver colour must have been replaced recently, i bought the car only 4 months ago. ive lifted bonnet and pressed the clutch pedal, and squeeky noises are coming from the slave cylinder. guess it just must be slave cylinder.
Old 04-12-2005   #12
Deckchair5's Avatar
Yes it looks like it's just the slave cylinder then.
Easy job to do; should be done in one hour tops
99 Bravo 1.2SX
Old 05-12-2005   #13
had it replaced at a garage today (slave cylinder). clutch feels much better now. just one thing now tho. every time i change gear i have to use a bit of force. not that much just a slightly more than usuall. also how eay is it to replace the rubber seal on the sunroof.
Old 05-12-2005   #14
Deckchair5's Avatar
Good. Might get easier with time, it'll certainly be doing more work now it's working properly
how easy is it to replace the rubber seal on the sunroof?
Not difficult. It can be done without removing the sunroof, just by moving the roof to different positions to obtain access. Often though the seal just compresses with time and gets cruddy on the outside lip allowing air/ water in. A good clean off of the seal outside edge and you can carefully prise the seal back into shape with a large bladed screwdriver from the driver's seat
My Bravo's on 107k and the sunroof seal's never needed total replacing, just some cleaning and adjusting
99 Bravo 1.2SX
(T) Punto Clutch Problem leon_judge Punto (Mk1) 9 11-12-2011 17:41
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
(T) Clutch slave cylinder Kendz Bravo / Brava 13 04-02-2005 13:43
(G) Changed Slave cylinder but can't bleed system!! zeph Tipo (Classic) 2 10-11-2003 23:57
(T) clutch slave cylinder colin w Bravo / Brava 0 20-08-2003 14:29
