Thread Tools
Old 05-12-2019   #1
Croatia
Fiat Bravo 1.4 12v 1997
Hello
I had my fiat bravo 1.4 12v for a few months, and it bugging me almost all the time. Engine cooling fan turns on just before temperature goes into red. I have changed thermoswitch, thermostat, relay and variable resistor on fan housing. Does anyone know what can I look for next. And also, does anyone have electric scheme for cooling system?
Any help is welcome.
Stjepan28 is offline Reply With Quote Quote
Old 11-12-2019   #2
Finland
Re: Fiat Bravo 1.4 12v 1997
Fan sound fine. Sure the waterpump is ok and there is not air in the system?
Neverth is offline Reply With Quote Quote
Old 14-12-2019   #3
Croatia
Water pump was changed about a month ago. I'll check for air in the system. Is there a way to exclude variable resistor and if there is, how would that change fan working process. I ask this because I took variable resistor from another car on which fan was working fine. And I want to be sure before buying it because it is pretty expensive.
Old 18-12-2019   #4
Finland
"Fan turns on just before temperature goes to red"
Seems right to me, sounds more like there is circulation problem with the actual cooling if that happens on normal driving. Does the needle stay level when driving? And goes to red fast/slow when stopping?
Old 19-12-2019   #5
Croatia
Temperature acts like under red is the middle, it cools it then and doesn't let it go to red.
I am not searching for problem fix anymore because I had a crash few days ago and car is totaled.
Thank you very much for your help.
Thread Tools
(T) 1997 fiat Brava 1.4 12v won't start? Help! johnwp Bravo / Brava 28 02-09-2011 02:16
Bravo (Classic) Fiat Bravo 1.4 12v 1997 Degas Grey - Modified Adrian Bravo Members Motors 62 09-11-2010 22:26
(T) brava 1997 1.4 12v help car los Bravo / Brava 6 11-06-2010 15:07
(T) Fiat Bravo 1.4 12v 1997 injection system shoelace Bravo / Brava 1 07-01-2010 16:18
