This is a topic I have seen on the forum before and is also one that I am experiencing with my Brava 1.4S. I am hoping that there is someone out there who may just be able to point us hot start problem types in the right direction.
Basically my car will start when cold (frosty mornings too) with no fuss at all. However, if the engine has run fully up to temperature and is switched off for longer than 10 or 15 minutes it will not start. Sometimes it will cooperate and after 15 minutes or so. The other evening it took 2 hours before it started.
I recently had an AA call out to look at it & the patrolman checked out the obvious things like spark, charging etc (all fine). He suggested it may be a fuel thing but could only suggest replacing the fuel pump and ecu relays, which I have done. The car of course started before he could do any further diagnosis! I have also replaced the plugs, HT leads and battery. All to no avail.
I would be really pleased if anyone could shed some more light on what seems to be a recurring problem with the 1,4 engine.
