Old 27-11-2005   #1
Unhappy washer jets
my washer jets dont work on my car! i pull the right hand stalk towards me but nothing comes out. i have filled the washer bottle up and the light washers work its just the ones on the bonnet. any help appreciated guys.
supacook2k is offline Reply With Quote Quote
Old 27-11-2005   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: washer jets
have you cleaned the washer jets with a needle? to clear any blockage.
you can check if there cblocked by removing the hose from the resevoir side and blowing through to the jets
Old 27-11-2005   #3
Re: washer jets
I had this with my passenger side one. i got a pin an cleaned out the hold on the jets an its started to work again, but its not the same as the drivers side. but works
Chris_267 is offline Reply With Quote Quote
Old 27-11-2005   #4
custard's Avatar
Trader Rating: 1
Re: washer jets
Quote Originally Posted by Chris_267
sometimes they get really blocked so an overnight soak in water may be needed. or just replace them
Old 27-11-2005   #5
Re: washer jets
Quote Originally Posted by custard boy
Al give that a bash.
thanks
Old 27-11-2005   #6
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Re: washer jets
Also worth checking along the pipes to see if any have come loose or split
Helz is offline Reply With Quote Quote
Old 27-11-2005   #7
Re: washer jets
had bravo hlx before sei sporting and had this problem,disconnect pipes from jets take out the pipe union to both jets ,clean in hot water and reassemble ,should be fine good luck
sei sporting 55 horses 1 jockey,hole in fuel tank and crap steering nu car soon
rob17 is offline Reply With Quote Quote
Old 29-11-2005   #8
Got My Own Title
Q TOY's Avatar
Q TOY has donated!
Re: washer jets
Sometims its worth running some hot (not boiling) water through the system. It can remove any soap depossites
Q TOY is offline Reply With Quote Quote
Old 31-01-2007   #9
Supercharger whine :)
Si - Punto's Avatar
Si - Punto has donated!
Re: washer jets
Sorry to ressurrect such an old thread but I didnt want to start a new one.
OK So I picked up the HGT last night and to my surprise everything seems to be working (well OK the stereo is knackered) but here's the problem, the washers arent working.
I have filled the washer bottle up but nothing is coming out of the jets. It sounds as if the motor is working but its just not coming out.
Basically what I want to know is...... How much of a b*tch is it going to be for me to disconnect the hoses, clean them out and reconnect them? (You've got to love the ammount of space to work under the bonnet with the 20v 5pot in there )
Aero kitted R53 Cooper S - Electric Blue/White Roof
Gone but never forgotten
'54 Steel Grey Punto Active 1.2 - '99 Nero Black Bravo HGT 20v - '98 Broom Yellow Punto GT3 1.4T - '07 Crossover Black Grande Punto Sporting 1.9 M-Jet
Si - Punto is offline Reply With Quote Quote
Old 31-01-2007   #10
Bravo 155 HGT
Trader Rating: 1
mountainmachine has donated!
Beach Bobbing Bob Champion, War on Iraq Champion
Re: washer jets
Prob a bitch but more of a bitch if you cant see!
mountainmachine is offline Reply With Quote Quote
Old 02-02-2007   #11
The Negotiator has donated!
Re: washer jets
Both my bravas had the same problem.
I suggest you disconnect the pipes just before the nozzles (they pull off quite easily, if any problem, use a bit of hot warm to heat (thus exapand) the rubber). Turn on the washer jet, you will probably see water come out the end of the hose, hence it's all working.
Do not try to test the non-return valve towards the end, it seems you need a massive pressure to open it up, I certainly couldn't blow through it.
Hence you will know that the problem is downstream from where you can see the screenwash coming out, and I expect, like me, you will find that cleaning the nozzles fixes it. I used a needle.
Now drives: BMW 635d (wow!)
Past:
Renault Laguna Coupe GT 180. Laguna Initiale dci. 52 Megane 1.9dCi, Y-reg Fiat Brava JTD (Pale Blue) (2006), '51 Fiat Brava 80 SX (black) (2006), M-reg UNO (2003-2004)
The Negotiator is offline Reply With Quote Quote
Old 02-02-2007   #12
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: washer jets
Quote Originally Posted by The Negotiator View Post
i tried a pin, but i think it was too wide because it made my holes wider, meaning the water came out quicker and will less pressure. i had to replace the nozzles after i did that, so make sure you use a thin pin that wont make the holes wider.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 02-02-2007   #13
Re: washer jets
They are very small, but maybe i used a very thin needle (I think I probably did) - they all work fine but it took a bit of effort, another Fiat design fault
Past:
Old 02-02-2007   #14
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: washer jets
i started making a list but my version of excel doesnt have enough rows. maybe i'll be able to squeeze it in to the 1,048,576 rows in excel 2007, but i've only got a few uses left before my license runs out. oh well.
Old 02-02-2007   #15
Re: washer jets
lol! The thing with Fiat is that they seem to mess up simple things? Just straight into my head I have:
Rear wiper design (most Fiats)
Rear wash wipe connector hose (Brava/o)
Washer jets (Bravo/a)
Temperature gauge unreliable (Bravo/a)
Tracking fault on rear (Stilo)
Door opening cable (G.Punto)
Crap door handles (Bravo/a)
etc. etc.
These are BASIC items which do not require genuine engineering, they have been around for decades and no modern car should have such faults. I mean fine, they're easy to solve but they're that easy to solve that I shouldn't have to solve them, should I.
If selespeed went wrong (which of course it does ) people understand that more because it's pretty cutting edge. But the rear wash wipe connector slipping off?! Unbelievable!
As you probably know, we have Renaults mainly in our family. Sure, you get problems (well, ok, we don't really but generally people do so I will allow that we're lucky/look after cars or whatever) but if problems do happen, at least they're on cutting edge kit. For example, the Laguna locking system was faulty on early versions with it losing its code. Unforgivable, except when you consider that it was a brand new code card system with hands free facility and new encryption technologies, so you kind of expect it to need time to be made perfect. Our 52 Megane II has it perfect, which means that the technology has been revised and fixed.
Past:
(G) Better Washer Jets faster4_tec Punto (Mk2/2b) 12 02-03-2005 09:36
Neon Washer Jets Digimods Leisure Lounge 31 06-09-2004 17:41
(S) neons and led washer jets stevob Punto (Mk2/2b) 15 12-07-2004 23:02
(S) How Do I Remove Washer Jets?? jdunderhill Punto (Mk1) 10 30-10-2003 23:00
(T) Washer Jets!!!!!!!!!!!! AJFisha Punto (Mk1) 2 02-07-2003 03:49
