M mikewigan New member Joined Nov 20, 2005 Messages 4 Points 2 Nov 21, 2005 #1 Brava "P" reg My drivers door wont open from inside or outside and i am struggling to remove the interior panel with the door closed.. Help !!! Any ideas? Cheers, Mike: thumbd: :bang:
sammiboo Patron member Parked in the garage Joined Oct 25, 2003 Messages 29,313 Points 4,416 Location Llanymynech Nov 21, 2005 #2 Has the cable/rod snapped. The panel is quite simple to remove, which part are you struggling with?
Helz Patron member Parked in the garage Joined Oct 7, 2003 Messages 24,349 Points 3,764 Location Carlisle, UK. Nov 21, 2005 #3 I thought I saw a post on here about removing closed doors recently but can't seem to find it. Is it impossible even with the drivers seat right back and down?
OP OP M mikewigan New member Joined Nov 20, 2005 Messages 4 Points 2 Nov 21, 2005 #4 how do i get the panel off when the door is closed , there are 3 screws near the front hinge. The rods apears to be moving the door pin, but not enough to open it somthing is not releasing the door lock Last edited: Nov 21, 2005
