Old 10-11-2005   #1
coolant temp sensor
does any 1 know were the coolant tempreture sensor is located
khanny is offline Reply With Quote Quote
Old 10-11-2005   #2
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: coolant temp sensor
What's the problem? Is it an erratic temp gauge?
2015 Fiat Panda Pop
Steven is offline Reply With Quote Quote
Old 10-11-2005   #3
ye and its putting ecu in backup mode
Old 10-11-2005   #4
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
I had an erratic temp gauge which turned out to be just the connectors behind the dials playing up. That wouldn't explain the ecu problem though...
https://www.fiatforum.com/showthread...ght=temp+gauge
2015 Fiat Panda Pop
Old 10-11-2005   #5
do u know were the temp sensors located m8t
Old 10-11-2005   #6
Cocoon Island Champion, Cupids Crush Champion, Crazy Pinball Champion, Pinball 7UP Champion, Rotamania Champion, Starsky n Hutch PinBall Champion
thermostat housing.
sumplug is offline Reply With Quote Quote
Old 10-11-2005   #7
cheers m8t found it the guy in the shop gave me the wrong part so i was looking 4 something totally diffrent, seems to have sorted the red light just a bit sluggish not half as bad though
Old 17-11-2005   #8
I want to check my temp sensor. Is it the blue plug / connector on the side of the thermostat and does it just pull off. Don't want to tug at something and break it.
darkblue is offline Reply With Quote Quote
Old 17-11-2005   #9
theres a metal pin u need to squeze in before pulling it of
(T) coolant sensor and water leak imperial21 Punto (Mk2/2b) 1 04-10-2005 13:08
(T) faulty temp sensor? - Punto mark1 Donal Punto (Mk2/2b) 5 16-09-2005 11:59
(T) Coolant themperature sensor amiller112 Cinquecento / Seicento 13 04-09-2005 12:51
(G) Coolant Temp warning lamp! siloam Ulysse 1 08-09-2004 22:04
(T) Temp sensor=Temp gauge sensor? CphFiat Punto (Mk1) 2 27-11-2003 18:13
