Hello everyone!
Just last week I got myself a '99 Brava 1.2 16v and I'm as happy as a pig in... well, you know what! I've been reading up on quite a few topics here and it seems to me this forum is a godsent!
Still, I have a few questions/small problems, if you could indulge me.
First off, the fog light switch. It works, as in, if pressed, it will turn the fog lights on, however the lights do not stay on unless the button's being pressed. If you press and let go, the lights will flicker momentarily and then be off.
I doubt this is a common problem but I'd appreciate any help. I'm stumped because obviously the relays are working and the switch does... well, half of what it's supposed to do! Could it just be a wrong switch? It is evident that the PO's did... stuff to the car but the switches and panels seem stock.
Next up, the rims. PO installed 15's. Which is all fine and dandy looks wise but I do think the 195/50/15's do slow the car down a bit. Now I do like the rims but, since a tyre change is needed at some point in the near future, should I just get four metal (like the stock ones) 14's and call it a day with the stock 175/65/14 tyres or are the ones on it fine and I'm imagining things?
On to another thing. I'm not used to driving a smaller engined car to be honest and it strikes me as kind of odd that the car needs to be revved that high to... "go", and I also find the 800RPM idle a bit low. Is this normal or should I be worried?
In reference, I used to drive a grand vitara (awful car, really), which was obviously really different and, while quite sluggish with it's 1.6 engine and it's immoveable 1.8 tonne mass, it was still a bit peppier than the MUCH lighter Brava.
That's all for now, and please excuse my long winded first post!
